2001 E-150 Suspension Help
Old Feb 3, 2008 | 03:25 PM
tweeker's Avatar
tweeker
Hey Guys,
I have a 2001, E150, 6cyl. with about 75,000 miles. I'm not sure what the current weight is, but with shelves,parts,wire spools,tools, and an open cargo area, the rear springs are FLAT. I don't think I'm near the GVRW, just worn out leaf springs. I installed a helper air bag system that needs the air monitored, one side is leaking. It's causing driving issues. I plan on adding a new front roll bar and possibly a rear to correct swaying and stability issues, and have already replaced all of the shocks.
I need to correct the saging rear end perminately without having to mess with it.
I've looked at these -add a spring- products from JC Whitney:
http://http://www.jcwhitney.com/auto...101&sku=helwig
Question 1: Do you think one product is better for my application than the others?
Question 2: Is it worth replacing the factory springs in conjunction with a helper kit or would the helper kit be enough?
Thanks Jeff
Old Feb 3, 2008 | 09:50 PM
Clubwagon's Avatar
Clubwagon
I have the helwig front swaybar on my E150 Clubwagon. It works great. I recommend it for all 150s. I don't have a rear bar but I did install an Add-a-leaf spring kit I got at Autozone for $22. It worked fine for my needs.
I may not have the load you do. I tow a car trailer with about 150 lbs of tongue weight and between 800 and 1000 lbs of equipment in the back. The add-a-leaf leveled out the van and really improved load carrying and handling.
I would buy Helwig's biggest helper springs or call them (I got their number off their website) and ask them what helper spring they have would give the most help.
I don't know if they are still listed or not but Rough Country used to have a big add-a-leaf listed in the JCW catalog.
Steve
'95 Clubwagon XLT
Old Feb 6, 2008 | 12:01 PM
suitcase's Avatar
suitcase
i couldn't get 4 leaf hellwig helpers from jcw so went w/3 leaf set .
seemto be working very well , after adjusting 2 ubolts on either side.
empty stance almost 2" higher, loaded [appx. 1500 lbs.]waaaay better than stock.
van is yr.2000. have used aadco rear sways for 25 yrs.-great.
