Fabworks
Old Feb 3, 2008 | 02:42 PM
FABWORKS's Avatar
FABWORKS
Cool Fabworks
I Have A 2002 F-250 .the Horn & Cruise Control Have Both Stopped Working . Fuses Are Ok . I Suspect A Loose Connector To The Steering Column . Any One Know Where The Connection Might Be Or Has Anyone Had Similiar Problem & What Was The Solution ? 7.3 Litre Diesel. Thanks For Any Help .
Old Feb 3, 2008 | 03:55 PM
kcb37's Avatar
kcb37
Find the horn itself, unplug the wires and have someone see hit the horn, see if you have power. If not make sure it's grounded.
If it's neiter, start working back till you find power.
I could be wrong but I think the horn is on a relay.
Old Feb 3, 2008 | 04:39 PM
FABWORKS's Avatar
FABWORKS
Cool FABWORKS HORN & CRUISE CONT. PROBLEM
I Forgot To Mention, When You Press Remote Lock, The Horn Does Work . So It Is Not A Bad Horn .
Old Feb 3, 2008 | 09:58 PM
subford's Avatar
subford
Sounds like you have a bad "Air Bag Sliding Contact (14A664)" AKA clock spring.
Old Feb 3, 2008 | 10:19 PM
Franklin2's Avatar
Franklin2
The clock springs are famous for going bad.
