I just bought a '99 Ford F-150 4X4. Here's the situation:
1. Horn does NOT work.
2. Cruise control does NOT work.
3. Airbag works fine.
4. Horn/cruise relay in engine compartment is good.
5. Cruise control recall performed already.
Could the clockspring be bad, even though the airbag is still functional?
Well it could be the clock spring. The cruise went in mine the culprit was the break switch had filled up with break fluid. As fare as the horn goes, do the horns themselves work, check them with a 12V power supply and see.
