ok need some help!
Old Feb 2, 2008 | 07:42 PM
smokn03's Avatar
smokn03
ok need some help!
found a 86 f-150 with a 302.says it runs awesome til it warms up.then runs really rough.is there anything these things had problems with that would cause this?thinking about buying it.but would have to drive it 2hrs home.thanks
Old Feb 2, 2008 | 07:57 PM
smokn03's Avatar
smokn03
also says it has a 5spd tranny.what year did they start putting 5spd tranny's in?
Old Feb 2, 2008 | 08:11 PM
bob_351's Avatar
bob_351
could be a vacumn leak, mine did this but only when warm. The front corner mount of the carb was cracked so as the metal expanded with heat it would push the carb upwards a tiny bit.
edit: It would be efi but it could have somthing to do with metal warping
with heat
Old Feb 2, 2008 | 08:12 PM
smokn03's Avatar
smokn03
so is 86 carb?or fi?
Old Feb 2, 2008 | 11:34 PM
Franklin2's Avatar
Franklin2
It depends on what engine it had. If I where to guess from the problem you described, it's probably a fuel injected 302, and it runs rough when the computer goes into closed loop mode. If you like piddling with wiring and don't mind learning about fuel injection, you probably can fix it. If it is fuel injected, here's a site you can study to see what you will be getting into. www.fordfuelinjection.com
Old Feb 2, 2008 | 11:48 PM
Surge08's Avatar
Surge08
If it is a 302 and not a 351 it was FI. Check the coil, it is known once it warms up for it to act up.
Old Feb 3, 2008 | 03:03 AM
smokn03's Avatar
smokn03
k thanks for the help.trying to decide if it is worth it.or should i pass?don't want to buy it and put more in it to fix it than it's worth.
