-71 429 heads
Old Feb 19, 2001 | 01:49 AM
mask's Avatar
mask
-71 429 heads
Hi, I have a -74 460 and I stumbled over some -71 429 heads
and I wondering if I can put those on without any problems?
What can I expect in comp. rise and horse power
I think its about 8,0 or 8,5:1 now.
Mask
Old Feb 19, 2001 | 08:40 PM
mavman's Avatar
mavman
-71 429 heads
It depends on which heads you have now. Some '74 engines had the large open-chamber heads (95cc), some had interceptor heads (88cc), and most had 92cc, casting #D3VE-A2A. If you have the latter, the new '71 heads with the 72cc chambers will give approximately 9.4 compression...and a huge jump in torque and horsepower. There is virtually no difference in the 460 heads, except the pre-72's used 18mm spark plugs, instead of the smaller 14mm. just check the chamber cc's of the '71 heads...I dont think they made any different ones, but I'm not positive.
Old Feb 19, 2001 | 09:27 PM
bb79ranch's Avatar
bb79ranch
-71 429 heads
The'71 429 heads have 75-77cc combustion chambers(base model/passenger car) & the 72cc heads mavman is referring to are the SCJ/CJ/Police heads. The combo you stated will raise compression like mavman has said between 9 to 9.5 to 1 C.R. There are major differences between your '74 heads(either D4VE or D3VE-A2A)and the '68-'71 heads. (A) like mavman said the plug size is larger. (B)429-460 heads from'68-'71 use screw-in studs, the'73 & on used bolts. (C) '68-'71 use valve stem guided rockers(rail rockers) with 1.75 ratio cast iron rocker arms, the'73 & on use pivot guided stamped steel rocker arms and have 1.73 rocker ratio. (D) '68-'71 heads have longer overall length valves and therefore use longer pushrods. (E) '68-'71s don't have the emission "tube" drilled for air pump use, so you can easily port the exhaust to help flow unlike your '73 & after heads. I hope this helps.
Todd
BB79RANCH
Old Feb 20, 2001 | 01:45 AM
mask's Avatar
mask
-71 429 heads
ok, Seams like a god idea. I don't now what condition these heads have but he wants 180$ for them. Can I use valves form my 74 in this head or any other parts? If there are in bad shape?
Mask
Old Feb 20, 2001 | 07:56 PM
hemi's Avatar
hemi
-71 429 heads
the cj head uses the smaller peanut plug also, because of intake port size. no room for the bigger plug.
Old Feb 26, 2001 | 03:13 PM
TBirdGuy's Avatar
TBirdGuy
-71 429 heads
The 71 heads will be much better because they'll yeild a higher compression and will make more power and torque. You'll probably have bigger valves in the 71', but I'm not sure. A sweet little trick to make it an adjustable valvetrain for the 71' heads that won't cost very much is to buy big block ch*vy Rocker studs and Lock-nuts and install them. Bolt the studs down to about 55 ft. lbs. of torque and you'll have a fully adjustable valve train. Cost will only be like $60.00 bucks and it's a quick easy change.
TBirdGuy
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
Old Feb 27, 2001 | 08:26 PM
mud_man's Avatar
mud_man
-71 429 heads
68-71=75.8cc 429
72-73=91.4cc 460
73-74 89.0cc 460 police
71-72 73.5cc 429 police or scj
72 91.4cc 429
75-78 96.2cc 460
this is what I understand
Old Jul 24, 2001 | 10:59 PM
72Tbird429pi's Avatar
72Tbird429pi
-71 429 heads
Mudman,
You don't have any casting numbers on hand for the later PI heads do you? Like the mid to late '70s casting numbers. I found a set of D3VE-e6 heads that are said to be a later PI casting. Are these legite? Send some casting info if you have it.
Thanks,
Brant Mason
ltyrsports(No Email Addresses In Posts!)
Old Jul 25, 2001 | 07:30 PM
85351ho's Avatar
85351ho
-71 429 heads
abrojal
Sep 17, 2016 11:59 AM
OregonHighboy
Sep 4, 2016 07:37 PM
markeyd
Apr 29, 2016 09:20 PM
The Masked Rider
Jan 28, 2016 02:43 PM
fordguy76
Oct 1, 2011 09:42 PM
