ebpv brake question
Old Feb 2, 2008 | 01:15 PM
heathrunkles's Avatar
heathrunkles
ebpv brake question
almost finished this mod with a three position switch( up for valve engaged manually, center for off and down for activation with the brake pedal) Everything works but I cant find the wire(I think purple with yellow tracer from other write ups I've read) for tC lock up. Anyone done this and where didyou tap the wire. Also on the tc line should I have a rectifier diode to on the line between the pcm and the tc to prevent voltage from the switch back feeding to the pcm. Thanks
Old Feb 2, 2008 | 01:23 PM
IDMooseMan's Avatar
IDMooseMan
No help from me on this, but I would like to see a schematic or pictures of how you did this. I keep hearing about installing the two-position switch, but I wanted to do the three-position switch like you've described.
Now I just need to know how it's done.
Old Feb 2, 2008 | 01:34 PM
heathrunkles
Got the Schematic of www.swampdonkey.biz The only thing I did different from the write up was not to leave the ebpv wired up to the PCM. Had to many problems with the thing sticking and cycling funny. I cleaned and lubed the valve good when I put the 1.0 a/r housing on. Now i just have to manually throw the switch to warm it up.
Old Feb 3, 2008 | 08:20 PM
heathrunkles
anyone with an auto done this?
Old Feb 3, 2008 | 08:25 PM
2 stroke man's Avatar
2 stroke man
where u gettin the power from?
Old Feb 3, 2008 | 08:28 PM
heathrunkles
Just used a spare fuse slot in the box
Old Feb 3, 2008 | 08:50 PM
2 stroke man
good was hoping you didnt go straight from battery
Old Feb 3, 2008 | 08:58 PM
heathrunkles
So any idea where to get the wire for TC lockup?
Old Feb 3, 2008 | 09:40 PM
fordman837000's Avatar
fordman837000
honestly I wouldn ' t hook it up to the TC lock up circuit but if you really want to the wire is at the transmission harness the easiest place to find the wire is on the pass side of tranny at the connector just pull the heat sheild off to find the wire make sure you put it back! Also make sure you use a diode on both the ebpv and the lock up wire!! I have heard too many bad storys about the lockup having problems and burning up the clutches in it or the solinoid in the tranny. I run mine without it I don ' t need it at all.
Old Feb 3, 2008 | 09:44 PM
fordman837000
Just cancel overdrive if you tap the gas after canceling od the TC will lockback up then you can use the ebpv brake ,but as you know once you hit the brake the TC unlocks again. To many people forget to flip the switch when coming to a stop stall the truck and or burn the clutches but just my .02 Let me know how you make out.
Old Feb 3, 2008 | 10:06 PM
ForemanES's Avatar
ForemanES
Follow these instructions, I did but didnt do the brake option so I just used a 2 position switch
Wire #1: Decide what you will use for a positive power source. Insure that this source is one that is "ON" only when the ignition is in the “ON” position. I recommend the 8 gauge, gray/yellow wire in the bundle under the steering column. You can also tap a fuse in the fuse panel. Run wire [#1] from the source to the switch, connecting it to terminal A2. I numbered the terminals as viewed from the back of the switch Install the inline fuse holder on this line. Make sure to leave 6"-12" or more of slack on all the wires. You can always bundle them up later.
Wire #2: Decide placement of a negative power point or ground, and run a wire from this to the switch, connecting it to terminal C1.
Connect one light to terminals A1 and C2; this is light A. Connect the other light to terminals B1 and C2; this is light B. Drill holes for the lights just above and below the switch. Install the lights with B in the top hole, and A in the bottom. I recommend this because when the switch is down, contact is made between A+C; when the switch is up, contact is between B+C. For simplicity, the diagram does not show the lights "crossed" like this.
Remove the black-hinged cover from over the fuel filter area in the engine compartment.
Wires#3 & #4: Run two wires from the switch through the firewall into the engine compartment. Connect one [#3] to terminal C2 and run it to the front of the engine. Connect the other [#4] to terminal B2 and run it to the brake master cylinder. If you have a horizontal diamond shaped plate about 2.5" wide just to the passenger's side of the clutch cylinder, remove the screws and run the wires through it. Otherwise, you may need to drill a hole. I always find that running the wires is the hardest part of any wiring project.
There should be a green wire by the driver's side of the master cylinder in the group of 4 marked "Center High Mount Stop Lamp Feed." This wire most likely will not be connected to anything. This wire is only energized when the brake lights come on. Connect wire [#4] to this one. If this wire is not present, use a voltmeter or test light to find a wire that is hot only when the brake lights are on and connect to that wire instead.
Locate the wires that travel from the PCM to the EBPV. There should be a 2-wire plug just under the turbo compressor. It is located towards the front of the engine between the turbocharger and the fuel pump on the intake side of the turbocharger. The plug is attached to the turbo pedestal. Disconnect this plug, and remove the loom (protective plastic shielding) on the plug side moving away from the turbo, to expose the wires inside. Slide off the loom until it reaches the intersection of the larger wire bundle. This will expose both wires; one wire is black w/gray, the other gray w/red.
The Two Rectifier Diodes that are required will each have a silver band around one end. Twist the wires from the "silver" ends together making a "Y.” The "black" ends will be at the top and the silver ends at the bottom of the "Y.” Cut the gray w/red wire 2"-3" before the plug, strip the insulation back 1/2" or so, and solder the black end on one diode to the end of the cut wire that does NOT go into the plug. Solder the black end on the other diode to wire [#3]; solder the two silver ends to the gray w/red wire that goes into the plug. The diodes are necessary to prevent the brake lights from coming on when the PCM operates the EBPV, and to prevent the PCM from receiving a 12v signal from wire [#1]. If you don't have a soldering iron, you can use crimp connectors.
Coat all the wire connections with several coats of Liquid Electrical Tape, then wrap them with regular electrical tape, and replace the loom. Also, cover wires [#3 & #4] with loom, all the way to the switch. Bundle up any excess wire with wire ties, and secure them all to prevent chafing. Install the switch in its hole, and replace the dash trim.
Automatic Transmission Circuit:
If the intention is to use the EBPV as a brake with an Automatic Transmission equipped vehicle, then an additional circuit is required in order to reap the most engine braking benefit from this application. This circuit will keep the torque converter locked up while the valve is in an activated state. In effect, it maintains engine RPM in relation to ground speed and prevents transmission disconnection, which would result in loss of engine speed, ultimately reducing the effectiveness of the exhaust valve as an engine brake.
Auto Trans Circuit Procedure: Run a wire from [#3] to connect to the TC lockup circuit. Install a diode on that wire with the silver end towards the transmission.
