Automatic Door Locking in Drive or Reverse
Old Feb 2, 2008 | 12:44 PM
fairwayford's Avatar
fairwayford
Question Automatic Door Locking in Drive or Reverse
Recently bought a used 01 Explorer Limited (my '00 caught fire in December).
Problem: I'm gradually picking off a few minor issues one at a time. This one has to do with the door locks. Everything works well, except that unllike my 2000, the locks on this one do not activate when you put the truck in drive or reverse and start moving.
I miss the sense of security knowing the doors are locked automatically, although I can lock them manually. Any help would be appreciated.
Old Feb 2, 2008 | 03:10 PM
scucci's Avatar
scucci
On older models that is known as Autolock and can be turned off or on at the keypad. I don't know if yours is the same. The steps to turn on or off are in the owners manual. If you need the owners manual go to the following link and register - it's free and you can get all the owners manuals and find out if you have any recall issues.
https://myford.fordvehicles.com/
Good Luck
Scucci
Old Mar 8, 2008 | 01:33 PM
fairwayford
did the programming and got the confirmation beeps and all, but the doors still don't auto-lock.
Old Apr 5, 2008 | 01:54 PM
fairwayford
Thumbs up Re: Automatic Door Locking in Drive or Reverse
Stupid me!
Apparently the same fuse that was causing my rear defroster not to work had something to do with this. Changed the fuse for less than $4, and whammo! Problem solved.
Thanks Scucci!
Old Apr 5, 2008 | 07:17 PM
winfordr's Avatar
winfordr
Fairway, thanks for posting the cure. Otherwise we would still be wondering.
