2002 superduty - turn signals stopped working. Hazards still work fine. Is there a fuse or relay that might have gone bad? I looked in the owners manual, and there is only one fuse I can find that refers to the turn signals and it is fine. Any suggestions?
well this depends does your turn signal click fast when you turn it on but not blink or will it not even click and is it one signal or both and front and rear
if its just one side and it still clicks then chances are that the bulb needs replacing the blinker will click fast if the bulb is burnt out but the hazards will still flash i dont know how but they do any way just a suggestion
