motor mounts
Old Aug 20, 2001 | 10:12 PM
60f100trk's Avatar
60f100trk
motor mounts
1m putting a 429 in a 1975 f250 4x4 (which origionally had a 360), i was told that i would be able to use the same towers for the motor mounts, but it looks a little off, what motor mounts should i be using? do i need to get different towers for the big block? this looks like a common swap, any advice from someone who knows for sure would be appriciated
one more question, this motor has like 2000 miles on it and its recently been having valve noise especially when i first start it, what might cause this? maybe the oil? or the filter?
thank you very much, you guys are awesome
-Sam
Old Aug 21, 2001 | 09:41 AM
tatonka's Avatar
tatonka
motor mounts
some one on ebay has the correct engine stands & mounts
for sale that you will need. go under ebay. then go under
ford 460 search you will see them.they also have a oilpan
that you will need if you do not already have one!
good luck!
Old Aug 21, 2001 | 05:33 PM
79F2504x4's Avatar
79F2504x4
motor mounts
