Sponsored by: Auxito
airbag sensor--where
Old Jan 31, 2008 | 08:05 PM
mobile home movers's Avatar
mobile home movers
2003 F150 supercab 4x4, flash code of 27, i call dealer he said it was front airbag sensor, been having trouble with connection and or ground where it mounts to truck, 4 wheeled thru snow bank light goes out... problem is i can not find where the sensor is mounted to the truck, have looked and looked and looked and........................help please.
Old Jan 31, 2008 | 08:20 PM
antony25's Avatar
antony25
sounds like a bad P.A.D. switch. Turn your key on and see if the p.a.d. light lights up for 2 seconds. If not you need a new switch.
Old Jan 31, 2008 | 08:40 PM
mobile home movers
I thank you for your input on the pad switch, however the question is: Where is the front airbag sensor located? Where does it mount to the truck?
Old Jan 31, 2008 | 08:49 PM
antony25's Avatar
antony25
If you are refering to the crash sensor it is built into the airbag control module located on the transmission hump under the dash.
Old Jan 31, 2008 | 10:31 PM
RJB1's Avatar
RJB1
I could be wrong! but if I recall there are is an airbag sensor (at least a connection) under the passenger kick board I had to remove when I replaced my heater core. I had to remove the airbag from the dash before removing the dash.
Old Feb 1, 2008 | 07:16 AM
mobile home movers
Would that be grounded where it mounts (transmission hump), hence one would be able to clean the mount and or connection? I am looking past the pad sensor because the code clears if I drive in deep snow, and stays clear for a day or two. I am sorry ,,, I see now you are speaking about inside the cab.
Old Feb 1, 2008 | 07:19 PM
antony25's Avatar
antony25
The module does ground at its mounting point but, code 27 has only to do with the pad switch not the module ground.
Old Feb 2, 2008 | 07:02 AM
projectSHO89's Avatar
projectSHO89
The dealer person you spoke to was wrong. LFC 27 is for a burned out bulb in the PAD switch assy.
Very common discussion here. SEARCH for "RADIO SHACK BULB" to find previous discussions including part number. About $2 if you can solder.
Don't waste your time on the other stuff you've stumbled into, it's a dead end.
Steve
Old Feb 2, 2008 | 06:19 PM
mobile home movers
code 27
Thank You very much to antony25 and to steve,,, for helping with what the
LFC code was and where to find the info on making the repair. Thanks again, Mitchell
Old Sep 7, 2010 | 12:01 PM
naiku's Avatar
naiku
I realize this is a 2 year old thread, but I did not see the point in creating a new one. Last week my truck started flashing code 27, flashes twice, then the airbag light stays on.
However, I am fairly certain that my P.A.D. switch does light up briefly when the truck is started. So, what else could be the cause of the code 27? I have read about loose wiring, could this be somewhere under the seat / passenger kick panel?
Thanks.
Norma stitz
Oct 16, 2016 10:30 AM
addem90
Escape & Escape Hybrid
15
Mar 27, 2015 03:01 PM
mudduc971
1997 - 2003 F150
Mar 12, 2014 12:43 PM
pohlro
1983 - 2012 Ranger & B-Series
Sep 25, 2009 05:41 PM
deereman4020
Feb 16, 2009 08:10 PM
