Offroad & 4x4
extending radius arms
Old Jan 31, 2008 | 06:54 PM
chrono4's Avatar
chrono4
what if i just took my stock radius arms, cut them, and lengthened acordingly with some dom or something? Would the stock brackets work? I dont know why they wouldnt.... I could even wrist one of them for some flex....... haha, like I need flex.......
Old Jan 31, 2008 | 06:58 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
as long as you made it beef i dont see why not, or you just can build your own from scratch....
Old Jan 31, 2008 | 07:00 PM
greythorn3's Avatar
greythorn3
allot cheaper then the cage arms too i bet!
Old Jan 31, 2008 | 07:01 PM
chrono4's Avatar
chrono4
Hm.. I'm going to look into a parts truck tomorrow, maybe I'll steal the arms off of that and experiment. I could make my own, but I'm limited on my tooling at the moment because all of the shops equiptment is in storage for at least a few more weeks. Maybe I'll do both then..
Old Jan 31, 2008 | 07:16 PM
STGFordCrazy04's Avatar
STGFordCrazy04
Finally a worthwhile thread!
Arent the stock arms cast? Might be tough getting a good penetrating weld without over heating the cast.
If it were me Id cut the arm off at the C bracket and build the arm from that. A single tube 1 3/4 .250 or .500 wall DOM would be stout.
Old Jan 31, 2008 | 07:24 PM
chrono4's Avatar
chrono4
Yeah, that was my second thought. If I cut the arm near the axle end (leaving plenty for adding supports) and then made it my own from there out. Maybe even some fancy smanshy joints on the end of it? I think that with a high nickel rod, and some good preheating, I can make a nice solid bead.
Old Jan 31, 2008 | 07:28 PM
STGFordCrazy04
Yeah Id use a threaded tube insert and a greasable heim. ni99 comes to mind for stick choice
Old Jan 31, 2008 | 07:29 PM
quadzjr's Avatar
quadzjr
i like the triangulated 2 bars conveging at a heim joint....
Old Jan 31, 2008 | 07:33 PM
STGFordCrazy04
Hooked at the front to rocks right?
I dont thing there is room. A 73-79 radius arm is 3-4" at the most just after the C. Seriously I think 1 3/4 DOM is enough.
Old Jan 31, 2008 | 07:37 PM
quadzjr's Avatar
quadzjr
hells yea!!!!
i dont disagree it will be enough, im just saying i like the 2 bars better....you could make it work....
Old Jan 31, 2008 | 07:39 PM
chrono4's Avatar
chrono4
Yeah, I'm not sure if there would be room to do a triangulated setup if I retained the stock C's. Buuttttttt..... If I coil overed the rear and tried a radius arm setup.... then I could do that there. I know a 4 link would be optimum, but I'm just experimenting with this pos.......
Old Jan 31, 2008 | 07:42 PM
quadzjr's Avatar
quadzjr
3 link it!!!!! then you'll get some hella flex...
Old Jan 31, 2008 | 07:44 PM
STGFordCrazy04
man quad....this is the first time weve disagreed.
I dont think you could convulge 2 bars that are 1 3/4 OD with only 3-4" to work with. They would start touching after a couple inches. Then you would just be running 2 bars for the sake of having 2 bars.
Maybe Im the one thats wrong. Ive never done this before.
Old Jan 31, 2008 | 07:47 PM
quadzjr's Avatar
quadzjr
nether have I, im not saying mines better, but i think it would look cooler....hehehe
STGFordCrazy04
quad I like you being Sergent at Arms more than VP.
