1978 - 1996 Big Bronco
Oil pressure sending unit?
Old Jan 31, 2008 | 10:39 AM
kameronth's Avatar
kameronth
I can't remeber where the oil pressure sending unit is on my 88 302. I even replaced when I swapped my engine not too long ago. Bad memory. Also, I want to out a mechanical gauge in. Can I just use the same hole that the stock one was in?
Old Jan 31, 2008 | 11:36 AM
Kemicalburns's Avatar
Kemicalburns
its above the oil filter. make sure to use copper line for the mechanical guage. you might have to get various fittings so you can keep both connected. otherwise you will get a CEL
Old Jan 31, 2008 | 05:08 PM
b4hntn's Avatar
b4hntn
I am glad I left the original disconnected. It trained me to look at the mechanical guage. A 1/4 X 6" brass nipple works great to screw in the block and gets the other connections out where you can see them. I stayed with plastic tubing, but covered it with split wiring harness and split a hose to cover the tubing going through the firewall.
