stuck thermostat??????
Old Jan 31, 2008 | 01:30 AM
kupaa's Avatar
kupaa
I was about to change the coolent in my engine and notice when i was draining the water from the drain plug under the radiator it was cold,maybe 100-110 degrees and the bottom radiator hose was cold,but the top hose was hot.I also check the water temp from the cap on the expantion tank with a thermometer and it moved to 100.It was driven over 15 miles so i no the temp was high and the fan was blowing hot air,any ideaThanks Chris.
Old Jan 31, 2008 | 03:29 AM
AustinS's Avatar
AustinS
The stock thermostat isn't set to open until 190º. So I think your okay.
But, since you're doing a coolant service, you could change it out. I change mine every other time I do the coolant, but I do take it out so I can rinse plenty of clean through the system and then reinstall it.
Austin
Old Jan 31, 2008 | 07:50 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Isn't it nice to know our beastley boys are doing a great job of cooling the water? Cooling has never been a problem with our massive cooling system.
Old Jan 31, 2008 | 09:49 PM
kupaa's Avatar
kupaa
Thanks guys but i ordered a billet housing and 203 thermostat from dieselsite just to be safe.
76gdmn
Jun 16, 2011 08:58 AM
riverbottom
1997 - 2003 F150
Aug 20, 2009 09:25 PM
KR1
13
Jun 25, 2009 01:59 PM
knash0727
Apr 10, 2009 12:27 AM
joe35098
Jan 17, 2006 08:09 PM
