Whats your Spring Fever Mods
Working on getting a yoke for my D44 so I can bolt a cv joint to it and finally have 4wd again!
After that, test it out and if all is well, then I'll sink some money into the engine.
I bought a 4v 600 cfm Holley carb that I just rebuilt and put on a edelbrok 400 performer intake. I'm not sure exactly what cam I want, but thinking about buying a comp cams kit with 260 cam, lifters, valve springs, seats, rods, and a double roller timing chain. With those and my headers, I should be running about 310ish HP and 430ish ft lbs at the rear wheels. NOT special, but better than the stock 150/300!
Well honestly the only mod (if you can call it a mod) I want to do is clean this truck from head to toe.... i mean everything carpets, seats. Wash and wax (2 times lol) The truck is getting real dirty and has quite a few nasty stains in the seat from coffee and water and I really want to get that puppy clean.
A $ mod though would be switch out the interior green lights for white LED's.
Wrapping up my project this weekend.
2006 F150 Harley Davidson 2wd 5.4L
STS Remote Turbo System
39lb Injectors
Front Mount Intercooler
4.10s
AF Gauge, Boost Gauge, Trans Temp Gauge
Billett 11" Converter
Factory Tech Valve Body Calibration Kit
Spiral CLip Upgrade
Deep Aluminum Pan
Hi-Carbon Overdrive Band
Already installed and tuned.
Installing the Boost Controller and Wastegate Muffler this weekend.
Then retuning for 7-8lbs Boost, vs. the 5lbs baseline that made 373HP/435TQ
39lb Injectors
4.10s
Spiral CLip Upgrade
Deep Aluminum Pan
EDGE PROGRAMMER!!!!!!!!!!!!!!!!!!!!!!! I just did my winter mod, AS 2.5" and some 285/70 A/Ts. Now I need the programmer and i would like a KnN airraid intake system for some extra ponies to get them bigger meats around! My baby 4.6 needs some HGH....hehe
Also, full out inside detail, take out the seats, steam clean...BOO YA!
I'm like FordTruckMan, I need to wash my truck, but they're expecting 4-9inches of snow tonight, so that doesn't make sense.
Installing the DVD player I purchased on ebay. Just got the factory harness. I don't think my kids will wait for spring on this one. Dropping a headliner in 10 degrees doesn't sound like fun
Installing a led light bar that needs warmer temps to install
On the fence with a roush supercharger, exhaust, cai, electric fans. The list is endless! Unless I can find a diesel Ex cheap!!
as is the popular answer.....wash and wax....we are still expecting snow here in flagstaff arizona so right now it does not make sense. Although give me a month or so and she is gettin lifted! Just need to find the time and the good weather to do so! Well good luck on the mods guys!
~Jstnromero
~Jstnromero
