reverse lights wont work
Old Jan 30, 2008 | 04:39 PM
Dan Taylor's Avatar
Dan Taylor
they have never worked since i got the truck. all fuses are ok and all the other lights do work. im thinking it could be something with the switch that turns on when i put it into reverse. its a 95 f150 4.9 shortbed. any ideas?
Old Jan 30, 2008 | 05:14 PM
stm250's Avatar
stm250
im thinking its the NSS (neutral safety switch) I have to replace mine soon also
Old Jan 30, 2008 | 09:31 PM
kcb37's Avatar
kcb37
Check your light bulbs first.
I bought an 84 Dodge aoubt 2 years ago. The low beams were both burnt out, all the parking lights, the brake lights, tail lights, not sure about the back up lights.
If the bulbs are good, check to see if you have power at the socket. If not then start tracing it forward.
Old Jan 30, 2008 | 10:02 PM
jr32560's Avatar
jr32560
my 95 e 250 does this once in a while-wiggle your shift lever-if that does not work check bulbs -then neutral safety switch-if all else fails check the bulb sockets-may be bad-seen it happen before-well never both at once!!! it could happen!
Old Jan 31, 2008 | 09:25 AM
toddol1971's Avatar
toddol1971
Is it a manual trans?
Old Jan 31, 2008 | 09:39 AM
Dan Taylor's Avatar
Dan Taylor
the bulbs are ok and it is a manuel transmission.
Old Jan 31, 2008 | 08:25 PM
toddol1971's Avatar
toddol1971
Maybe there is a bad ground to that light. trace the wires back & see.
Old Jan 31, 2008 | 08:37 PM
Dan Taylor's Avatar
Dan Taylor
i did follow the wires and it seems that the ground is also for the brake light and turn signals which do work.
Old Feb 1, 2008 | 09:53 AM
toddol1971's Avatar
toddol1971
Maybe the light socket is bad You may need a whole new assembly.
Old Feb 1, 2008 | 11:05 PM
kcb37's Avatar
kcb37
Did you see if you have power to the lights?
If they don't check your neutral safety switch.
If they do your have a bad ground or a bad socket.
Old Feb 3, 2008 | 06:44 PM
Dan Taylor's Avatar
Dan Taylor
theres no power going to the light sockets. tommorow i got some time to work on the truck and ill check the NSS. ill get back to you guys tom. any1 here ever replace or have any ideas for what to do with the switch before i go out and buy a new one
Old Feb 4, 2008 | 02:05 PM
Dan Taylor's Avatar
Dan Taylor
im now 90% sure its the NSS but i am having a hard time finding it and the haynes manuel doesnt say much at all. where is it located and what does it look like?
Old Feb 4, 2008 | 10:06 PM
Old_Paint's Avatar
Old_Paint
There is no NSS on the M5OD. ONLY a switch for the backup lights. There IS a clutch safety switch (pressure switch), but no NSS. The only switch on that tranny, if it's an M5 will be the one for the backup lights.
Old Feb 5, 2008 | 03:23 AM
toddol1971's Avatar
toddol1971
Isnt it the same way for a 4spd too? I thought it was, but sometimes my thought process does'nt work right LOL.
Old Feb 5, 2008 | 11:31 AM
Dan Taylor's Avatar
Dan Taylor
where is this switch for the back up lights? im thinking of just rewiring it right now to a toggle switch
