Sponsored by: Real Truck
GEM?!? Problems?
Old Jan 30, 2008 | 10:50 AM
welderford390's Avatar
welderford390
Unhappy GEM?!? Problems?
I have a early 99 F-350 CC 4X4 auto. Well this is how it all started the 4X4 light would come on shortly after driving the truck. The problem was there was no four wheel drive, even when I locked the hubs. So I started reading posts on the ESOF problems.
I checked all the relays, fuses, switch all the way to the transfer case. I'm not getting any power to the transfer case motor. I pulled the motor and hooked 12V to it and it works fines. Transfer case seems to shift fine and the hubs work manually I'm not worried about the auto hubs at this time.
After doing the research on this site about these problems I'm starting to lean towards the GEM. Can anyone help me and tell me if it is the GEM? The other problems that I'm having are the dome lights have a mind of their own. The compass goes on a off, stays on most times. Occasionally I'll loose speedo and tach. And every now and then the wipers do their own thing too. Also I noticed that something is drawing down the batteries. I pulled the fuse to the GEM to reset it and this is when the wipers start going crazy and the dome lights and still no power to the transfer case. If it is the GEM can I order it from anyone other than the dealer? Its a 99 F-350, 4X4, auto. I'm really in a bind, my 95 had a fuel line rupture yesterday.
Thanks for the help.
Brian
Old Feb 1, 2008 | 01:56 PM
welderford390
New batteries and alternator checks out, still same problems.
Old Feb 1, 2008 | 02:44 PM
zx250's Avatar
zx250
Of the next Riffraff East
Did you check the relays under the hood, the ones that are in their on little covered block beside the main Power Dist. Box?
Old Feb 1, 2008 | 02:49 PM
zx250's Avatar
zx250
Has it been raining there lately? Others have had similar issues when water leaks from windshield onto the back of the fuse panel and creating all kinds of problems.
Old Feb 1, 2008 | 05:55 PM
welderford390
Yep I've checked the relays, even switched em with the trailer towing relays that I know work. Haven't had any rain the truck is actually in a garage started noticing the symptoms late last fall and put the truck away. Haven't had time till now to look at it.
Old Feb 1, 2008 | 09:10 PM
99f350sd's Avatar
99f350sd
What he said....
preppypyro
31
Mar 5, 2025 03:54 PM
davec2003
Jan 23, 2017 08:11 PM
mark21224
Feb 18, 2014 07:29 AM
Ryno22980
Jan 17, 2014 02:17 PM
breakout99
Dec 21, 2011 08:03 PM
