Fuel guage getting weird
Old Jan 30, 2008 | 10:00 AM
Bookman's Avatar
Bookman
For a long time the guage has read 3/4 when full ok I can handle that but now it has started to drop the reading more rapidly. The last time I filled up thinking it was empty it was half full. Do you thing with the age a 71 250 that just the float has a problem or the whole sending unit. Quite a price difference. My thought was the float is getiing water logged so to speak.
Old Jan 30, 2008 | 10:08 AM
BradyCouchman's Avatar
BradyCouchman
first i would say check your grounds, and all conections. sometimes things get lose or coroded (spelling?) and then it wont read right.
Old Jan 30, 2008 | 11:27 AM
Bookman's Avatar
Bookman
Been there done that I think it is the float because it is a linear drop just happening faster. It has in the past just stopped registering probably from a bad connection but now it just drops faster than before.
Old Jan 30, 2008 | 11:33 AM
wizzard351's Avatar
wizzard351
the float after alot of years will rub a very very small hole in it,them gas gets into it and wont let it "float" to the top like it should. these floats are still avalible from ford number dummy can give ya the part number
Old Jan 30, 2008 | 02:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The float is made from two pieces of copper soldered together.
Solder flakes off, gas seeps in, float slowly settles to the bottom of the tank.
The following parts are still available from Ford.
C0AZ-9202-B .. Float
C1TF-9276-A .. In-Cab Fuel Sending Unit Gasket
D7TZ-9275-G .. Fuel Sending Unit (compete assy. comes with the above).
The float fits ALL Ford sending units car & truck 1957/79.
Old Jan 31, 2008 | 10:40 AM
Bookman's Avatar
Bookman
Thanks guys thats where I'll start.
