Fuel Filter Questions
Old Jan 30, 2008 | 09:10 AM
ncheavymetal's Avatar
ncheavymetal
FTE NC Chapter
Question Fuel Filter Questions
I did a search first but didn't really find the answer I was looking for.
I've changed fuel filters on other vehicles before but not my excursion yet. I have the filter and tools to do the removal/installation and the ability. What I need to know is do I really have to unplug the pump relay/pressure switch on the passenger side under the kickplate? All I've done in the past was to make sure I took to gas cap off to relieve pressure.
Any tips/suggestions?
Thanks for the help.
Old Jan 30, 2008 | 09:15 AM
i eat hybrids's Avatar
i eat hybrids
I would unplug it. It cant hurt right? BTW, i shadowed a mechanic when i graduated from HS. We were workin on a pickup and he had to change a numb of things including the fuel filter. He just unscrewed the thing and replaced it. Didnt tough the relay/ pressure switch.
Old Jan 30, 2008 | 09:43 AM
njstevens's Avatar
njstevens
No you do not need to unplug the relay or pump . Just swap it out as you would others. MAke sure you have the right one before starting . lol ( just kidding)
Old Jan 30, 2008 | 10:53 AM
rcracerx's Avatar
rcracerx
I just opened the gas cap to relieve pressure. It did have a little extra fuel come out when I removed it but nothing too messy.
Carl
Old Jan 30, 2008 | 12:01 PM
ncheavymetal
FTE NC Chapter
Thanks for the responses. I had a feeling it was an unnecessary step. But I just wanted to make sure.
Old Jan 30, 2008 | 12:34 PM
Roody727's Avatar
Roody727
If your a diesel ... open the water seperator valve ... this will drain the fuel bowl, remove any moisture, and relieve the pressure ....
Old Jan 30, 2008 | 06:43 PM
71-4R3SONS's Avatar
71-4R3SONS
Yep... I got this from our friend Monsta a few months back:
Originally Posted by Monsta
There is a fuel pump fuse in the fuse box underneath the steering wheel. Pull while the engine is running to release the fuel rail pressure. The number of the fuse is listed in your owner's manual.
I also popped the gas cap too. It worked like a charm.
Have fun!!
