Clutch
Old Jan 29, 2008 | 10:43 PM
chumigma's Avatar
chumigma
Clutch
Is there anyway to tighten a clutch on a 99 F350?
I took it Ford who said they replaced it a year and a half later its starting to slip i had my old one for longer than this
Old Jan 30, 2008 | 08:26 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I don't know the answer to your question, but I will bump this for you.
Old Jan 30, 2008 | 08:43 AM
03_PSD's Avatar
03_PSD
do you have any mods done to your truck? increasing the hp will shorten the life span of a OEM clutch.
Old Jan 30, 2008 | 09:04 AM
pullinair's Avatar
pullinair
You cannot tighten the clutch. With your new clutch and no power adders, you should see the same life span out of it as with your first one. Two questions for ya, is it slipping or ist it having trouble going into gear?
If it is slipping, you have a problem with the clutch itself not holding and will need a new one, without a doubt.
If it is having trouble going into gear and grinding, you may just have a bent shift fork. The only other thing that would cuase grinding is a bad syncro on a certain gear.
If you have no clutch pedal at all it could be your slave/master cylinder.
A sloppy clutch pedal could be the result of the teflon spacer the goes inbetween the master cylinder rod and clutch pedal. In other words we need more info to help you pin point your problem.
Post back with some more details and we will help you get it diagnosed.
Ok , i reread your post and i see that it is slipping. I do have t add that I have the stock NAPA replacement (prescion junk), with a kevlar pilot bearing and it holds well in the 80 econo tune when I get on it. Something either failed in your new OEM untit like a pressure plate spring. I would suggest giving southbend clutch a call or a LUK dealer and descreibe what power your putting to the ground and get a recommendation from them on what to install. I also heard the pedal is light on these heavier clutches, alot lighter than the stock replacements. Which is a plus. THe key thing to remember is that no matter what replacement clutch you get, get the the kevlar pilot bearing to replace the matal roller bearing type.
