Explorer lift gate panel - how do I remove it?
Old Jan 29, 2008 | 08:19 PM
m4sports's Avatar
m4sports
I think my tailgate lock actuator is shot. I am new at the whole fix-my- truck -myself thing, but I figured this would be a good place to start. To replace the actuator, I need to remove the interior panel (liner) on the tale gate. I poked around and removed the handle. The rest seems be be held on with hidden clips. I want to avoid cracking the liner and was wondering if there are any tips to getting out (insert a puddy knife in a certain spot and pry, utter special incantations over the gate)? Any feedback is appreciated.
Old Jan 30, 2008 | 07:41 AM
mason's Avatar
mason
Yes, the panels are held by clips. I've never had a problem with cracking a panel. Start at one corner and just pull the panel off. You can use a putty knife to get starte. You may want to wrap the putty knife if tape so you don't scratch the paint on the door.
Mason
Old Jan 30, 2008 | 07:57 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
What year is your explorer? Diffrent bodystyles have diffrent methods of removal. On several of the older bodystyles (pre 2001) if you start prying at the bottom you will break off the hooks that hold the panel in and there is no repair for that other than a new panel. If it is a 1999 as your profile shows pop a little oval cover in the middle of the panel right where the glass latch is and remove the phillips screw under there, then pull at the top of the panel above the rear glass there are 4 clips above the glass that will pop loose and another one on each side of the glass. After those are loose lift up on the panel and it will just lift right out. reverse to reinstall. good luck its a pretty easy job once you get started.
bruno6491
Apr 15, 2011 11:48 AM
mercury_kid
15
Apr 7, 2008 06:56 PM
LARIAT 85
Exhaust Systems
Jan 4, 2008 07:04 PM
88Vmax
1997 - 2003 F150
Jul 29, 2007 01:53 PM
ebexp94
Jun 19, 2007 11:51 PM
