99 E-150 code 0340 help !!
Old Jan 29, 2008 | 07:09 PM
redfalcon1's Avatar
redfalcon1
Unhappy 99 E-150 code 0340 help !!
I'm finally addressing trouble since sept.,code 0340 cam circuit failure or fault,truck feels like it's missing and wants to cut off ,mechanic has replaced cam sensor,but still getting service engine soon light & 0340 fault,anyone out there have this stickler of a problem.I've noticed it seems to act up more when it warms up ?I don't know ?? Thanks....................
Old Jan 29, 2008 | 07:46 PM
Ultramagdan's Avatar
Ultramagdan
Welcome!
Is this a diesel? I think that code is for the 7.3. Here's one of the threads I found on it: https://www.ford-trucks.com/forums/5...highlight=0340
Old Jan 30, 2008 | 12:42 AM
redfalcon1's Avatar
redfalcon1
No,not a diesel..........
Old Jan 30, 2008 | 05:29 PM
Ultramagdan
To get the best help with that one you will want to post in the tech forums. Click on the Forums tab at the upper left and scroll over the boards. The 97-03 is a good with that will help your application and there is a board for the 5.4 engine. Of course there is also one for your van.
Good Luck!
Old Jan 31, 2008 | 12:47 AM
redfalcon1's Avatar
redfalcon1
Thanks Dan,we Ended Up Needing To Teach The New Sensor To Start @ #1 Injector, Truck Hasn't Run This Good In Awhile 88k.need 5 More Years Out Of It ! Redfalcon1
engine1
New Member Introductions
Jul 18, 2008 04:41 PM
b58stewart
May 19, 2008 08:00 PM
capt.rick
Aug 19, 2007 07:47 PM
bigal66
Apr 3, 2007 09:11 PM
David Beahan
Feb 6, 2007 05:05 PM
