Sponsored by: Auxito
Update
Old Jan 29, 2008 | 06:53 PM
firefighter1416's Avatar
firefighter1416
Smile Update
A few days ago a posted about a vibration problem well i figured some of it out. Turns out the clutches in my limited slip were gummed up and dry, so took them apart cleaned them up, used some additive and good as new. so if anyone has any vibrations or sounds like a tire rubbing on the rear end area the clutches are a possible culpret. Also has any one on here had any good luck fixing the crack that starts at the bottom right hand corner of the glass on the driver side door. i have had it fixed 3 times no luck at all. any way thanks for everyones help
Old Jan 30, 2008 | 12:48 PM
TEKWS01's Avatar
TEKWS01
There is a tsb bulletin for this. you have to purchase a support kit that installs inside the door. I did this to my truck two years ago and have not had it crack again.
Old Jan 30, 2008 | 05:26 PM
firefighter1416
where do i look up tsb bulletins at
Old Jan 30, 2008 | 05:31 PM
TEKWS01's Avatar
TEKWS01
motorcraftservice.com
