Alternator headaches
Old Jan 29, 2008 | 03:36 PM
Project_Roxanne72's Avatar
Project_Roxanne72
Question Alternator headaches
I am currently restoring a '72 F100 thats seen better days. I bought a universal wire harness and everything seemed to be going good. Until the batteries die. I have already determined the problem to be in the alterantor. I have 4 terminals on the back of mine. (1) GRD=ground, (2) BAT=battery, (3) FLD=???, (4) STA=???. What are the STA, and FLD terminals for and where should I wire them to. Thanx J.R. Oh yeah you can go to http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=320 050944&albumId=0 to view pics of the progress I'm making along the way.
Old Jan 29, 2008 | 05:37 PM
ford390gashog's Avatar
ford390gashog
The ground is unused, The FLD is Field and STA is stator they both go to the voltage regulator.
Old Jan 29, 2008 | 05:38 PM
72shortford's Avatar
72shortford
The sta is stator connector, this should go to your electric choke. The fld is a field connector and should go to the voltage regulator. Make sure all your ground cables are good especially one from engine block to cab firewall. Hope this helps.
Old Jan 29, 2008 | 05:42 PM
72shortford
ford390gashog is right about the groud terminal on back of alt...
Old Jan 29, 2008 | 06:14 PM
Project_Roxanne72
Smile
Thank you sooooo much
Old Jan 29, 2008 | 07:21 PM
1967 Turbo 6.9's Avatar
1967 Turbo 6.9
How about putting a few in Your gallery here. We can't see Your My space without joining. Always like seeing what others are up to!
