Aerostar Ford Aerostar
%$#%$@$#$! Waterpump!
Old Jan 31, 2008 | 07:18 PM
93nighthawk's Avatar
93nighthawk
Talking
Originally Posted by eehoepp
I also have a 95 3.0L 2WD van. Your story sound like mine.
First the "weak" water pump": It's possible. When I replaced the water pump on my van (about 5 years ago), ALL the fins on the impeller were gone. I mean completely corroded away. The impeller was just a spinning disc on the shaft. Odd thing was that the van did not overheat unless stuck in stop & go traffic in the summer. I drove the family on a 2000 mile round trip just before I changed the water pump, and the engine temperature only started creeping up when I got stuck in Montreal rush hour. The 3.0L just doesn't seem to generate a lot of heat that the coolant needs to carry away. I have to cover the grille every winter or the engine won't get warm enough to go into "closed loop" and then gas mileage suffers badly.
Second: The stock heater just does not put out much heat, even with the grille covered and the engine at temperature. I replaced the heater core last fall, and made sure all the blend & diversion doors in the heater were working properly. Changing the heater core helped the heater output somewhat, but it still can't cope with such a big air space on its own.
My van didn't have the rear heater from the factory, but I made one myself because the kids were freezing in the back seat. It belts out heat and I have to throttle back the coolant flow through it or we all cook now.
If you can add a second heater, do it. Otherwise, dress warm.
Cheers,
Eric
That was one of the priorities in my Aero, rear heat/air. Like today, it finnally got above 0* (+3 to be exact, Heat Wave! )
Old Jan 31, 2008 | 07:21 PM
96_4wdr's Avatar
96_4wdr
kick around your local junke parts emporiums.
may be a large truck heater core in box you can pull. should be set up with 12v fan already.
easy to mount behind 2nd seat and face foreward
these will thaw icebergs with enough hot water
i have to run a radiator block in the winter here and we seldom see below 20d F. i use a plastic garbage bag, easy to route in and pull around as needed to cover 1/2 to 3/4 of radiator.
don't cover the auto transmission or pwr steering fluid cooling coils
zjmj17
Dec 10, 2016 05:01 PM
chasehoe
Mar 27, 2015 12:43 PM
joegeds
27
Feb 1, 2014 07:27 AM
Banshee426
45
Jun 4, 2010 12:53 PM
niteowl
19
Dec 1, 2003 09:20 PM
