will the dist for a 351m-400 fit a 460? I have heard a 460 dist fits a 351c. I have a 79 f150 4x4 that i am putting a 460 into and want the electronic dist and just woundering if i could use what i had or if it was off to the junkyard.
I've also done it. Works pretty good for the most part. I will agree with mil1ion about the anti-seize. They are bad about the base getting corroded and not wanting to move later on in vehicle life.
TBirdGuy
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
thanks guys, this is good news, one less item I have to look for!
now to find out what that strange noise coming from the front end was last night. I think it was a wheel bearing.
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bd4df2d3a303367.gif
A cat startled awake by the fan belts when the engine started up maybe ?
Dennis
