Clutch quick discconect problem.
Old Jan 29, 2008 | 09:37 AM
Carson1219's Avatar
Carson1219
1992 250 351 5-speed with concentric slave, i think this is the ZF tranny. Replaced clutch, slave and line in september, might have 3000 miles on swap. When i am bouncing through the field the clutch line will pop out of the slave cylinder. Now i have posted this before and was told it wasn't snapping in all the way. That was good advice but that did not cure the problem. When the line pops out it bring the little spring clip with it. My question is: Is the clip shot or the slave cylinder side of it?
Old Jan 29, 2008 | 04:31 PM
subs1000w's Avatar
subs1000w
just out of couriosity why did you replace the line in the first place could you try the old line if you still have it
Old Feb 2, 2008 | 10:26 PM
Carson1219's Avatar
Carson1219
The old line was leaking down through the bell housing, why i have no idea ai think it was just plain worn out.
