Sponsored by: Innova
Hooking up Amp Need Help!
Old Jan 29, 2008 | 09:33 AM
hdfxrusa's Avatar
hdfxrusa
I am in the process right now of running the lead to my battery and can not figure out a way to use the clamp that came with the amp wiring kit. have the Scosche E3200 kit.
Any help would be much appreciated.
HDFXRUSA
Old Jan 29, 2008 | 11:03 AM
RangerPilot's Avatar
RangerPilot
What's the clamp look like?
I use the dual-prong connector to connect the wire to the amplifier, and no connector to connect the wire to the battery (due to the very odd shape of the Explorer battery clamps).
The most important thing is to get a solid connection, making sure that a good bit of the wiring touches the battery post. If you have a picture of your battery terminal, that would help greatly.
Old Jan 29, 2008 | 12:47 PM
hdfxrusa's Avatar
hdfxrusa
I worked it out!
Thanks for the reply!!!!!
Old Jan 29, 2008 | 10:44 PM
RangerPilot
Good job. How's it sound? What setup are you running?
