Replacing outer window belt seals
Old Jan 29, 2008 | 08:54 AM
ghunt's Avatar
ghunt
Is there a trick to these or do you just pull them up and out?
Tried to do them last weekend, they wouldn't budge, but I think they were frozen on.
Old Jan 31, 2008 | 07:24 AM
TexasGuy001's Avatar
TexasGuy001
I assume your talking about the rubber and felt strips at the bottom of the window where it rolls down. I replaced all 4 on my truck. You'll have to take the door panels off though. It makes it 20 times easier. They should just pull off. If you replace the inner ones on the door panels you'll definitely want to take the panels off to keep from breaking them.
Old Jan 31, 2008 | 08:25 AM
ghunt's Avatar
ghunt
Well door panels aren't gonna help with the outers...
Old Jan 31, 2008 | 09:01 AM
TexasGuy001
It sure does. I should know, because I replaced them on mine. It gives you more room to see what you are doing and move them around. Besides that it is easier to grab ahold of them. You can probably do it with out taking them off, buts it easier if you do. The should just pull off. If you have new ones, you can see the type of clips that are used. They can be hard to get off.
Old Jan 31, 2008 | 09:18 AM
lmd91343's Avatar
lmd91343
100% agreement. You need to remove the door panels to easily replace the outer strips.
