hub conversion kits
Old Jan 29, 2008 | 08:43 AM
sparky86ford's Avatar
sparky86ford
hub conversion kits
having alot of trouble out of warn auto hub locks. interested in c/o to manual hub locks, truck is a 86 f-150 4x4, will i have to have the spindle nut conversion kit also ? any help would be greatly appreciated.
Old Jan 29, 2008 | 10:11 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Yes, to convert from auto to manual, you will need the manual hubs and the conversion kit.
Old Jan 30, 2008 | 11:53 AM
blue beast's Avatar
blue beast
When was the last time the bearings and the hub internals were greased and lubed?
For some reason I have been running into a lot of people almost running their front
bearings dry!! Yes you need to actually grease them puppies it's not like the rear end
getting lube all the time!! I would try some light oil on the hubs if they are dry in there
and as soon as possible take it apart and grease them puppies. I prefer manuals but a
properly lubed and maintained auto system can work for a long time!!
Old Feb 3, 2008 | 11:12 AM
xpl951's Avatar
xpl951
My 83 with the dana 44 ifs did NOT need the kit. Mine is the 5 bolt hub and the 3 bolt WILL need them.
