I was double checking the cylinder order on my 390 before hooking up my spark plug wires. I learned something really interesting. According to Steve Christ's Big-Block Ford Engines book, you need to be careful about your spark plug wires. This is what he says.
Make sure the numer -7 and -8 wires don't run parallel to eachother to each other...the reason for this is induced firing (page 10)
So I put one on the opposite side of the wire comb from the other. I am not sure if it will make much of a difference, but it was interesting. I am going to start up my truck tomorrow.
Bear 45/70, I have to ask you where you got the info that induction has been stopped by the new spark plug wires. I thought unless sheilded all wire through which current is passed creates a magnetic field around it. Your knowledge on this matter would be appreciated. Besides autos you, must also be into firearms and perhaps hunting. We visited your state this past year, quite impressive. Kotzy
Like mentioned, with the wires of today, it's less likely to have issues with wires too close to each other. If they are old and dry, then it will likely have issues.
If you truck ran fine before, then moving them won't affect anything. If you have a random miss or the like then this might help.
No it won't fire a plug, but the voltage it induces in that parallel wire of the next cylinder in the firing order may start ignition of its charge prematurely. That has been shown to happen. We even saw it a couple of times on 8mm wires. Doesn't cost anything to be cautious , kotzy
I can remember when the great break through in plug wires was the use of silicone as an insulator. Then came the 7mm wires then the 8mm wires. But induction is not the issue and never was as the current created by induction would never be enough to fire a plug. It's getting an actual spark between the wires that causes the problem. Back in the old days to tell if your plug wires were an issue was go out and lift the hood on a dark night and look for the blue glow and arching from wire to wire or to the engine itself. The new style insulation pretty much prevents this. Induction is gonna happen even if you used 1/2" thick insulation.
I run plain ol Azone specials on everything(including the race car). For the money they can't be beat and lifetime warranty if you pay for it. I just choke when they list these $100 "super duper" 8 mm wires that are suppose to be all that. I guess if you run a really big ignition box it's needed, but for stock stuff I keep it simple.
I know my '67 F100 really cooks the wires, as they get pretty stiff after only 1 yr on the truck. Still no problems with them, but the heat surely get to the insulation.
Why Larry are you doing this again? Guys he use's Azone stuff allright.... 4 sets of 00 copper wire silicon covered jumper cables on the Race car...Dont let him BS ya....
The old wires also had carbon cores that tended to break up after a few handlings. And Freighttrain, maybe you might want to try Ford Racing's wires. The small block sets are 9mm and run about $40-45 a set. Damned things last forever too. I had one set that were on my 95 E150 van, that were several years old when I sold it. And if they'll hold up in a box like that, they'll do in anything else.
