1978 - 1996 Big Bronco
Wiring Problems
Old Jan 28, 2008 | 04:34 PM
87BroncoCrazy's Avatar
87BroncoCrazy
Wiring Problems
I have a 1987 bronco and the chassis wiring harness recently got ripped out by getting wrapped around the front drive shaft. i removed it to repair it and now that its in, there is a four hole female connector that i cannot find the male end to. i was wondering if anyone knew where this went, or where i could find a wiring diagram better than the standard manual for the truck. any help is appreciated, as im new to the truck
Old Jan 28, 2008 | 11:11 PM
justshootme84's Avatar
justshootme84
Get a Haynes or Chilton repair manual for your rig, look at the wiring diagrams in there. Be sure your basic items like lights and igintion work, then go to engine sensors if you don't find where the plug goes by the wire colors. JSM84
Old Jan 30, 2008 | 12:11 PM
blue beast's Avatar
blue beast
Autozone.com has wiring and vacuum diagrams online for free!! Which wires got
yanked and what ones did you find spots for? Xcase, trans, fuel pump are all in that
area that I think of right now. There is usually some connectors left empty does it
look like it was connected (wearmarks, scratches etc) before?
