Lifting points
Old Jan 28, 2008 | 12:55 PM
Scot Clark's Avatar
Scot Clark
Lifting points
Hi:
Does any one know where the exact lifting points are for F150 '80 thru '86
for using a 2 post auto lift?
Old Jan 28, 2008 | 01:01 PM
hoxiii's Avatar
hoxiii
The frame about under the front cab mounts and under the front rear leaf spring hanger or as close to the combination above as you can get.
Justin
Old Jan 28, 2008 | 01:16 PM
Franklin2's Avatar
Franklin2
You usually have to use adapters for a truck. They are just blocks that go on the lift, to compensate for the amount the frame kicks up after the cab.
Old Jan 29, 2008 | 03:50 PM
Scot Clark's Avatar
Scot Clark
Thanks guys! I got the lift but am still waiting for the truck adapters
to be sent.
