I have a ford f150 97 model and the heater does not seem to be heating as well as before. I have changed the thermostat and it seems like it should get hotter than it is.
Welcome to FTE Bayouself! Do both heater hoses in and out of the heater core get hot? They should. Try removing the **** from the temperature control and switching it for the fan ****. If the **** trick doesn't work and the hoses are hot, then you may have a blend door problem. Good luck!
