FPR Screen?
Old Jan 28, 2008 | 09:23 AM
custom_nirvana's Avatar
custom_nirvana
FPR Screen?
Where is the fpr screen?
Old Jan 28, 2008 | 10:21 AM
IceboxFX's Avatar
IceboxFX
Fuel Regulator Screen Cleaning
The fix is simple. Take off the cover over the fuel filter, 1/2 socket does the job. Place a towel or shop rag under the fuel regulator!!!! There are two 10 mm bolts just to the right of the fuel filter, take both out making sure you put them back the way they came out. Gently pry the fuel regulator away from the fuel filter housing, making sure you don't drop the o-ring. You will see a small screen about 1/4 inch. Using a small screwdriver or q-tip w.out the cotton ball on the end, wipe the screen and then put everything back together. The material you get off the screen I have been told is from o-rings. The fix will only take 15 to 20 minutes. If you find the regulator is blocked, clean it, install new fuel filter, and it shouldn't need to be done again for 12 months.
Replace your black cover and you are ready for a test drive to see if you made any difference. You should definitely feel a difference in throttle response. You will actually have more boost pressure.
from http://pages.prodigy.net/stevebaz/_i...az/index3.html
that should help. the fuel pressure regulator is bolted to the right side of the fuel bowl.
-brian
Old Jan 28, 2008 | 10:44 AM
kawa's Avatar
kawa
X2 What he said!!!!
Old Jan 28, 2008 | 01:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
here is another write up:
http://www.FTEs diesel forums.com/co...el%20Regulator
