460 truck heads
Old 04-09-2001, 05:20 PM
tbolt 460's Avatar
tbolt 460
tbolt 460 is offline
460 truck heads
are 87 460 truck heads any good for performance.Can get a set with 10,000 mi on them but didnt know about valve size,CC's port size ect
Old 10-27-2001, 10:18 PM
DeGideo's Avatar
DeGideo
DeGideo is offline
460 truck heads
The now defunct Super Ford Magazine had an article on late-model EFI460 heads back in a 1996 issue entitled,"Low-Buck 460 Heads".They were E7TE castings that they used for the test.Basically they go on to say in stock form,these heads don't flow well,but they can be ported&given a valve job so they can flow almost like F.R.P.P. 460CJ heads!They also point out that a lot of these EFI460 heads sit in junkyards (i.e. you can get 'em cheap!).They state they cost about $100 at the junkyard. That's excellent given what can be done to them.I'd tell you to buy those EFI460 heads....
Old 10-27-2001, 11:50 PM
ludis's Avatar
ludis
ludis is offline
460 truck heads
Most (all?) '87's were still carbed. EFI on the 460 became common only in 88. Service manuals and parts books imply that EFI might have shown up late in the 87 model year - that's why the early-EFI heads have an E7 part number.
Ludis
Old 10-28-2001, 11:20 AM
DeGideo's Avatar
DeGideo
DeGideo is offline
460 truck heads
The EFI460 started being produced in April of '87.It was a mid-year deal,so the EFI460 didn't show up in great numbers until the 1988 model year.
Old 10-28-2001, 11:54 AM
busdriver1's Avatar
busdriver1
busdriver1 is offline
460 truck heads
I have heard (don't know if it's true) that you can only bolt an EFI manifold to the EFI heads because the bolt pattern for the intake manifold changed to clear the injectors. Something to keep in mind.
Old 10-28-2001, 07:28 PM
DeGideo's Avatar
DeGideo
DeGideo is offline
460 truck heads
I don't think that's true,because of the magazine article itself.You can't use non-EFI intakes on a EFI460 block,unless you had the EFI heads ported to match up to the intake that you chose.With a good porting,a four-angle valve job,and larger 2.19"intake&1.76" exhaust valves,a set of EFI460 heads can be real performance heads. These can be used on any 429,or 460.The worst thing about late-model EFI heads is their stock valve sizes:1.975" intake&1.65" exhaust. True,EFI460 heads-box stock-aren't a good choice for a built-up early 460 because of their small ports&valves,but they would "bolt on".All the ports would be mismatched,however,because of the size of those on the EFI intake are small,just like on the EFI heads. Any use of EFI460 heads,on a 460-4V engine will require port work.Installing a larger set of valves is a very good idea,too.The EFI460 heads are just a cheaper alternative to more expensive castings,or aftermarket heads.
Old 10-28-2001, 07:43 PM
DeGideo's Avatar
DeGideo
DeGideo is offline
460 truck heads
If you had a set of EFI460 ported&fitted with larger valves, I'd go with a set of headers.Stock EFI460 exhaust manifolds are extremely restrictive. Many aftermarket suppliers offer EFI460 truck headers.To gain some more power,you could always smooth out the header ports,and match them up to the ports on the heads.
Old 10-29-2001, 09:35 AM
f350brocno's Avatar
f350brocno
f350brocno is offline
460 truck heads
My 1992 460 engine has an EFI intake and D0VE-C (1970) heads. The intake manifold runners are roughly 0.25 inches higher than the D0VE head ports at the tops. You can port the head to match the intake, but the intake is too thin to remove much material. The bottom of the intake runners mismatch by almost a half inch. The intake manifold is higher. (might be good as a reversion reflector?). There is very little mismatch in the widths of the intake ports. You will also need D5TE exhaust manifolds (or headers) not the EFI units. The EFI exhaust manifolds will not even cover the larger D0VE exhaust ports.
john
Old 11-08-2001, 12:37 AM
mrlaserboy's Avatar
mrlaserboy
mrlaserboy is offline
460 truck heads
[font size="1" color="#FF0000"]LAST EDITED ON 08-Nov-01 AT 01:37 AM (EST)[/font][p][QUOTE]The now defunct Super Ford Magazine had an article on late-model EFI460 heads back in a 1996 issue entitled,"Low-Buck 460 Heads".[QUOTE]
Can anyone get me a copy of this article? I've been looking around for that article but haven't been able to find one in the libraries.
Dustin Siebert
1988 Bronco XLT
460EFI/C6/BW1356/
D44IFS with 8 lugs(open)/10.25 FF(Lockright locker)/4.56
8" susp/2" body
35's-street/38.5's-trails
[link:www.superford.org/registry/index.php?vID=45|http://www.superford.org/registry/index.php?vID=45]
Old 11-09-2001, 06:34 PM
DeGideo's Avatar
DeGideo
DeGideo is offline
460 truck heads
I can get a copy of that article out to you.
Old 11-09-2001, 06:37 PM
tbolt 460's Avatar
tbolt 460
460 truck heads
SURE i'll take a copy, THANKS
Old 11-09-2001, 10:12 PM
DeGideo's Avatar
DeGideo
DeGideo is offline
460 truck heads
tbolt 460,I just sent a copy to Dustin.If you'd like a copy,you can tell the Administrator to e-mail me with your mailing address.I'd be happy to send you out a copy,then.
Old 11-10-2001, 06:50 PM
cyberdiamond's Avatar
cyberdiamond
cyberdiamond is offline
460 truck heads
I also would like a copy if that is ok my email is
stevewilliams@picknowl.com.au
Thanks
Old 11-10-2001, 07:09 PM
DeGideo's Avatar
DeGideo
DeGideo is offline
460 truck heads
Steven, I tried e-mailing you twice and both got kicked back into my box.Try contacting the Administrator so they can get me your mailing address if you want a copy of that EFI460 heads article.
Old 11-10-2001, 07:14 PM
tbolt 460's Avatar
tbolt 460
460 truck heads
just sent u my address
Quick Reply: 460 truck heads
