Sponsored by: Real Truck
ABS module... again
Old Jan 27, 2008 | 07:19 PM
hang10's Avatar
hang10
ABS module... again
Had the ABS module replaced under warranty at 4,000 miles because it was making a grinding noise at start up.
Truck now has 8600 miles and the module is grinding again. No longer under warranty (it's an 03). Is this part something that goes out every 4,000 miles? I doubt it, is there a common cause of this failure? Of course, I would like Ford to do this on their dime. I know that isn't going to happen, just wondering if this is something I will have to plan for every so often.
Old Jan 28, 2008 | 11:42 AM
Mercury45's Avatar
Mercury45
my abs system growls at me every time i ign on... its like "ign on, wait 3 - 5 secs, growl )
i think its normal - i think its a self test
kenny
Old Jan 28, 2008 | 01:20 PM
hang10's Avatar
hang10
Yes, it is the self test but mine was replaced because I was told that when it growls, the motor is going out. I found the paperwork on the replacement. It also said the ABS on the rear brakes were not working because of the defective motor, which I don't recall being the case but apparently they tested the brakes.
You might want to get that checked just to be safe.
Old Jan 29, 2008 | 05:18 PM
Mercury45's Avatar
Mercury45
well if the abs fails, ill have regular brakes, which is perfectly fine with me
kenny
Old Jan 29, 2008 | 05:48 PM
hang10's Avatar
hang10
Roger that.
