fuel line disconnect
Old Jan 27, 2008 | 06:49 PM
Tyson82's Avatar
Tyson82
I know Im an idiot, but Ive pulled these a hundred times.
Im pulling the fuel pump on my '94 F-250 w/ 460 V8.
I was able to get the 5/16" line off but the 3/8" just won't budge.
Im using this type of disconnect tool:
disconnect tool
Are other types of disconnects superior, or am I just a moron?
thx
Old Jan 27, 2008 | 06:52 PM
superduty4x4's Avatar
superduty4x4
Chances are someone or something pulled too hard on the line at one time and the little retaining clip inside is bent. I had that happen on a fuel filter once, it was a real PITA. Really jam that disconnect in there and try it, if it doesn't work you'll probably have to get a thin pick and try to straighten the prongs of the clip out. I'd replace the clip once you get the line off.
Old Jan 27, 2008 | 06:55 PM
quicklook2's Avatar
quicklook2
you really have to jam it in.
soak the fitting with wd40 or something like it.
push the line in some and spray again.
Old Jan 27, 2008 | 07:00 PM
khadma's Avatar
khadma
Carpenter Local 745
I hate to say this but, you might have to give the tool a bit more force to get it to disengage the fitting. I like to push the fuel line against the tool so that the fuel line goes "past" the "hump" on the Filter/pump. Pushing the line towards the pump/tool/filter gives just a little more clearance for the prongs and room for the tool to do it's job.
Old Jan 27, 2008 | 07:09 PM
quicklook2's Avatar
quicklook2
it is like once you get it than you see what needs to be pushed and pulled.
Old Jan 27, 2008 | 07:21 PM
khadma's Avatar
khadma
Carpenter Local 745
Kinda like that.
Your avatar is still spooky though! Just kidding.
Old Jan 27, 2008 | 10:04 PM
Tyson82's Avatar
Tyson82
Well, I don't think this disconnect tool is pushing the pins far enough out. Im gonna get a different one tomorrow. It only has to be just a little bit thicker and I think it will be fine.
thanks for the thoughts
Old Jan 28, 2008 | 05:14 PM
Tyson82's Avatar
Tyson82
haha.
It was just that type of disconnect tool. That type tapers at the end and I think that it just wasnt pushing the pins out far enough. Bought one that doesn't taper and the line popped off first try.
thanks for the help guys.
Old Jan 28, 2008 | 05:55 PM
quicklook2's Avatar
quicklook2
glad you got it off.
seems so easy now, doesn't it?
Old Jan 28, 2008 | 06:47 PM
Tyson82's Avatar
Tyson82
Its all about the right tools. One of the reasons Im such a crappy mechanic. hehe
Old Jan 28, 2008 | 09:54 PM
khadma's Avatar
khadma
Carpenter Local 745
Your only crappy if you ask us the same question over and over again,
Your a better mechanic now that you moved up a notch. (with more tools too).
