torque
Old Jan 27, 2008 | 06:25 PM
jim'shighboy's Avatar
jim'shighboy
torque
how can I get more torque out of my 360 FE
Old Jan 27, 2008 | 07:50 PM
Bear 45/70's Avatar
Bear 45/70
Stroke it to a 390.
Old Jan 27, 2008 | 07:54 PM
85e150's Avatar
85e150
Yup, that gives you more cubes and higher compression and thus will give you more low end and carry it through to the higer revs as well should you build the engine up.
The 360 suffers from low compression, and the easiest way to fix that is using the 390 parts.
Check the threads here, many many on this subject.
