another ID question
Old Oct 26, 2001 | 12:33 AM
orangeford's Avatar
orangeford
another ID question
How do you guys translate this stuff is there a book? Anyway can somebody ID this motor? I believe it was originally from a 78 f350 Possibly from a 75 lincoln. I know it was in the truck not sure if it was original.
Intake manifold D6-VE-9425
Heads D3-VE-A2A
Block DIVE-6015-A2B
I am not sure of crank number because it and the pistons are in the block. Is there any way to read the crank without puuling it out? Thats all I could find. The heads, intake, water pump, and distibutor are all off and sitting next to the block.
Old Oct 26, 2001 | 01:55 AM
Mil1ion's Avatar
Mil1ion
another ID question
[font size="1" color="#FF0000"]LAST EDITED ON 26-Oct-01 AT 02:58 AM (EST)[/font][p]https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bd908d31915589c.gif
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bd908bf18eee2eb.gif
1st character = Decade> A=40's B=50's C=60's D=70's
2nd Character = actual year of decade.
3rd character = Car line
4th character = Engineering Division
5th = -
6th,7th,8th,9th Characters = Base Number for item
10th = -
11th character = Suffix or Revision
NOW,
In your case
D6 =1976
V= Car line, V=Lincoln
E= Engineering Division
9425 > Intake manifold Designation number
? = Should be a letter Like A,B,C,etc
? = Design revision
A= 1st revision ieit could mean the
addition of a vacuum connection hole)
Heads D3-VE-A2A
D3=1973
V= Lincoln
E = Engineering Division
A2A=1 st revision with 2 more revisions after the first.
(I think)
Block DIVE-6015-A2B
D3= 1973
V-Lincoln
E-Engineering Division
A2A=1st revision ?????
EDIT
On the crank there should be a letter/number combo.that is visible by turning the crank with the pan off.
Hope this has helped !
Dennis
78 F-150 429CJ 465,000 KM.(Original Owner)
68 Mustang 289 Sunlit Gold 80,000 Miles(second Owner)
64 1/2,260 Pre-World's Fair Mustang #8092
64 Fairlane 500 S/C,waiting for a 390 4-Spd
If The Girls Don't Find You Handsome,
They Should At Least Find You Handy!
Old Oct 26, 2001 | 09:18 AM
Bill_Beyer's Avatar
Bill_Beyer
another ID question
E stands for Engine, not Engineering Division. A = Chassis, B = Body, E = Engine.
Old Oct 26, 2001 | 01:52 PM
Mil1ion's Avatar
Mil1ion
another ID question
E in his case stands for the ENGINE.
The fourth Character!
Is the Engineering division Space
Thus, the FOURTH character could be an
A for Chassis
B for Body
E for Engine
M for SVO motorsport
X for Muscle parts program
I should have made it E = engine for his numbers, you're right there.
Dennis
Old Oct 26, 2001 | 02:17 PM
wtroger's Avatar
wtroger
another ID question
You also need to remember that D6 in D6-VE-9425 means the part was either first produced or engineered in that year D6 = 1976 so lot later built parts can and do retain that original part number.
Old Oct 27, 2001 | 02:19 AM
ludis's Avatar
ludis
another ID question
The "car line" character specifies the first car line that the part was used on or designed for. The same part/number can also be used elsewhere. Lincolns were the premier usage of the 460, hence a lot of 460 parts have a V car line designation.
The "revision" code doesn't mean just 1st design, 2nd design, and so on. It also specifies the difference between say a 302 manifold and a 460 manifold that were both introduced in the same year for the same car line.
These numbers can be looked up in the parts books and microfiche that Ford dealers used to use. Used books/fiche show up occasionally at swap meets and on EBay, and usually sell for significant ca$h.
Ludis
Old Oct 27, 2001 | 02:25 AM
ludis's Avatar
ludis
another ID question
Some more info...
Trucks used D1, D5, and D9 dated blocks. (The D9 block was used till the end in 1997.) Your 78 should have had a D5 block.
Ludis
Old Oct 30, 2001 | 10:57 PM
orangeford's Avatar
orangeford
another ID question
So are these heads and block good years of production? Or should I look for a earlier set of heads like 68-71 if so where do ya look junk yards? I would imagine theyre already gone.
Old Oct 31, 2001 | 01:04 AM
Mil1ion's Avatar
Mil1ion
another ID question
[font size="1" color="#FF0000"]LAST EDITED ON 31-Oct-01 AT 02:06 AM (EST)[/font][p]https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bdfa24b345310e4.gif
Look for 70-71 Lincolns,T-Birds,Mercury's, & Mid 70's Pickups(usually first to go)
Too Bad you don't live where I do .
There are TWO 70 Lincolns with Complete Big Blocks sitting in them.
Right Now!
Dennis
Old Nov 28, 2001 | 02:13 AM
bigred78's Avatar
bigred78
another ID question
Old Nov 28, 2001 | 01:06 PM
dazzleaj's Avatar
dazzleaj
another ID question
I must have the same motor in my truck, The guy said he thought it was from a 74 Lincon.
A book that I have states thath those heads have 91.5 cc chambers. There were 2 de-tunings, this was the first to 8.5:1, the next was in the 75 production year (74 people year) to 8.0:1. These heads with TRW pop up pistons can give good compression. If you want the specifics, email me and I will give you the info.
I am going to pull the mill out of the truck and put it in my 69 Mach 1 in a few months. I think it is a good motor to work with.
A.J.
buckin69bronco
13
Jun 23, 2015 01:37 PM
Mudshovel_009
Mar 10, 2015 12:22 AM
68cabby
Mar 25, 2013 08:50 PM
onetwin
Aug 29, 2007 11:48 AM
rig_pig30
Jan 9, 2005 05:15 PM
