6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Sound With DPF gone??
Old Jan 27, 2008 | 02:39 PM
Hollywood2005's Avatar
Hollywood2005
I just put on the MRBP 4" dual exiting exhaust on my truck; it looks 100 times better and a little louder (not even close to what I want) so I am curious with the DPF removed what does it sound like??
I have been watching the site closely waiting to hear milage,power and sound improvements
I will be doing a new wheel package, tuner and possibly a DPF delete in the spring and curious what to expect
thanks
Old Jan 27, 2008 | 03:11 PM
SouthTexasDiesel's Avatar
SouthTexasDiesel
Hopefully this week I'll be putting some video and sound clips on when I get my 5" delete pipe in.
Old Jan 27, 2008 | 03:39 PM
spatel23's Avatar
spatel23
can you post some pics of that dual set-up. Im thinking I want to do that a little down the road
Old Jan 27, 2008 | 04:05 PM
SANDDEMON08's Avatar
SANDDEMON08
I'm running the DPF delete and you get a little more exhaust and turbo sound but not much. In front of the DPF is a cat which still muffls the sound alot.
Old Jan 27, 2008 | 04:08 PM
SouthTexasDiesel
So did you just remove the DPF and leave the CAT?
Old Jan 27, 2008 | 04:39 PM
SaharaF350's Avatar
SaharaF350
is the dpf delet pipe just a bolt in?
Old Jan 27, 2008 | 05:40 PM
SouthTexasDiesel
The one I just bought is a 5" direct bolt on, connects to the downpipe, and has the sensor bungs TIG welded.
Old Jan 27, 2008 | 06:19 PM
SANDDEMON08
I made my own that bolts up were the DPF bolts on. So far i have left the cat in place
Old Jan 27, 2008 | 07:09 PM
SouthTexasDiesel
Ok, that's what I thought. Hopefully when I get my pipe in it will sound like a real truck and not a hair dryer.
Old Jan 27, 2008 | 07:33 PM
Hollywood2005
I will try to post some pics of the set up in a day or so. It only took about and hr to install ith to guys
I am thinking I will do the DPF delete when the tuners get rid of the Regen mode.
Old Jan 27, 2008 | 08:43 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Hollywood2005, we have had the Regen/DPF delete tunes available for over a month now. Give us a call
Old Jan 27, 2008 | 09:39 PM
Hollywood2005
ah I didn't realize they were out yet??? I knew they/you were testing. Which tuner do you sell? and what kind of results are you getting? MPG and Power??
I have been watching this site waiting for someone to post some #'s
I still want to wait a little bit; I only have 9,000 km's so far and want to wait to see if anythong "bad' Happens by removing this stuff
Old Jan 27, 2008 | 09:44 PM
SANDDEMON08
I've had matts tune on my truck for about 1,000 miles with no problems, take a look a the thread 6.4 perfomance mods i started. The milage is up on mine about 30%.
Old Jan 29, 2008 | 09:50 AM
stroke this's Avatar
stroke this
30% thats great,I'm ready to delete mine.
I took a trip this weelend about 500 miles,got between 11 and 15 mpg and every time I stopped and let it Idle I noticed it was in regen.
On the way back I was getting 16 to 21 and did not notice a regen at all.
Also I used C-tane boost on the way and did on use it on the return trip.
If it can be done without problems I think this would be a much better truck without the DPF.
Old Jan 29, 2008 | 10:18 AM
Hollywood2005
I am ready anytime to do it but do not want to mess around in the cold It's -20C here today.
I have been watching U-Tube to get a listen to these trucks with the DPF removed and I am sold. Between the sound,performance and MILAGE gains and hearing that you can switch back in 15 min!!!
I just need to know which tuner to buy?
