Rear Anti-lock
Old Jan 27, 2008 | 02:12 PM
Shovelhead 93's Avatar
Shovelhead 93
Question Rear Anti-lock
My rear anti-lock light has started to come on on my 87 F-150 4x4,fluid seems fine,I didnt even know I had anti-lock on the truck,or is it some other problem,I dont see a pump under the hood for anti-lock,what could it be?
Old Jan 27, 2008 | 04:23 PM
Linemo's Avatar
Linemo
to start it uses a wheel speed sensor that bolts on top of the rear axle it reads off a toothed gear that bolts to the ring gear inside the rear axle! The usual if you have checked fluid is to unbolt and replace the sender you can get them from dealer around $25 dollars
Old Jan 27, 2008 | 04:39 PM
quicklook2's Avatar
quicklook2
below the driver on the frame rail is the rabs control.
just follow the brake line.
Old Jan 27, 2008 | 06:33 PM
Shovelhead 93
thanks I will have a look
Old Jan 27, 2008 | 10:26 PM
TexasGuy001's Avatar
TexasGuy001
The rear abs control module is behind the glove box on my truck.
Old Jan 28, 2008 | 12:53 PM
jr32560's Avatar
jr32560
87 and 88 are frame mounted-well they are on mine!
Oct 20, 2010 11:11 AM
jmmartin
Mar 23, 2010 01:33 PM
Gorgoth
Jul 16, 2009 02:59 PM
Pittsburgh-05HD
Feb 13, 2006 07:19 PM
ajstephan
Aug 14, 2000 12:04 PM
