360 turn 390
Old Jan 27, 2008 | 10:00 AM
jim'shighboy's Avatar
jim'shighboy
360 turn 390
for all my needs who should i buy from to turn my 360fe into a 390? crank,rods,etc. has knock seems loud top end but not a tinny knock runs smooth when warm. may need complete rebuild, I got lots of time. thanks
Old Jan 27, 2008 | 10:02 AM
jim'shighboy
by the way also trying to get as much torque out of this engine as I can, want to pull w/it
Old Jan 28, 2008 | 10:31 AM
Mike G's Avatar
Mike G
First off, welcome aboard!
Secondly, you need to pul the motor apart to see what the condition of the block is. If you are lucky, perhaps you can get buy with a cleanup on the cylinders and not need new slugs. That being said, if you have a local machine shop you favor, they can probably get all you need for the upgrade (crank and rods) and still re-use the 360 pistons. The shop I use was able to get me parts for the same or less than a kit would run....
--Mike
