still leaking
Old Jan 26, 2008 | 10:18 PM
hefmo's Avatar
hefmo
still leaking
Hi everyone,sorry I have been away from forum, but job travels are crazy. I left forum last time with diesel leaking so I changed orings on water/fuel separator valve,ran truck watched for 10 minutes,no leaks,drove for 45 minutes opened hood and fuel in valley not much maybe 1/2 teaspoon, had valley good and clean before so leak is fresh,is there any other common places for this... 2003 f250 7.3 thanks so much
Old Jan 26, 2008 | 10:45 PM
white Buffalo's Avatar
white Buffalo
The only thing I could think of is making sure it's not leaking from:
1. the fuel filter cap.
2. Follow the fule lines from the fuel filter housing
3. The fuel line leading from the fuel tank/pump to the fuel bowl
First when the engine is cold I would spray some simple green and wash the engine off so you can see where the leaks are starting from
Old Jan 26, 2008 | 10:53 PM
hefmo's Avatar
hefmo
thanks white buffalo,going try and find time for this tommorrow, thanks for info, I'm going to clean up area, and really stick my nose and eyes in there. once again thanks and will let know results.
Old Jan 26, 2008 | 10:56 PM
white Buffalo
Some of the spots can be hard to see, I used a clean paper towel to wipe the fuel fittings and see if any diesel fuel was leaking when I did the reg return.
