Best Mods
Otherwise, the first thing that comes to mind is manual hubs if you have ESOF.
Happy spending!
http://www.team-mudd-racing.com/Team...0Evolution.htm
my personal opinion is GEARS and HEADERS!! headers to wake up the 10er, and gears to put it to the ground!!
as for hubs, good mod, not a required one, but can cause less headaches in the future. tuner..........i had a hypertech at one time, wasn't impressed, sold it and havn't got anouther one yet, but heard good things about diablo sport tunner, and SCT chips (especialy the 5 position chip)!
but i still say GEAR, HEADERS/EXHAUST, and nickle and dime the rest of the mods as you get the money!!
See...the best mod depends on your needs for the truck...IMO.
biz
Here's a little insight to what I have done.
Headers, waste. Purchased hooker ceramic coated for $800 and gained about nothing. Sounds good but thats about it.
Flowmaster cat back 3", it works ok after removing all the junk clamps and welding it all. Sounds good and gained about .5 mpg and a little mid range rpm torque.
TB spacer, junk. Wasted $40 on a piece of aluminum that did nothing but cause a leak between the tb and spacer. Sold on ebay the next day for $10.
K&N Filter and intake tube. Works good, mild performance gain. Mostly throttle response and high rpm "seat of the pants" power increase.
Diablosport Predator. At first I thought I had thrown more money away and then I started playing with it. The factory tunes are garbage but you can modify them which is really the best part of this tuner. I have adjusted pretty much everything to my liking and the end result has been outstanding. Well worth the $400.
One day I got a wild hair to pull off the converter to see if maybe it was starting to plug. I pulled it off, looked in it and my jaw dropped. This thing is heavily resricted. I've seen the inside of many converters before but this one is plain ugly, So I welded in a 3" pipe, turned off the rear O2 heaters with the predator and went around the block..... Power for days..... By far one of the best things I have done to this truck. I get almost 3mpg more than before and it runs great. I had to do some further fuel and spark adjustments (basically lean out) to remove the extra fuel going into the exhaust ford pre-programs to help the catalyst keep its heat low. This could be achieved with a high flow cat also.
Gears....... I have a friend that has a f350 the same as mine only is a long bed. we both have the same nitto 315's but I have 3.73 and he has 4.88. even with all the mods I have on my truck, his blows mine away. Even in mileage, he gets 1-2 more than I do any given day. I'm scheduled to get a set of 4.88s in soon. The shop I'm taking it to is charging $1640 to do it. Low cost compared to a $4k blower and the 92 octane fuel you're going to need to buy to run it.
but i would put the gears first and then the headers, on my mod list!
2 wasted sets of pipes!! save your money and get you a GOOD set of banks or dougs.....
1. 4.56 or 4.88 gears
2. 4.5" suspension lift (or at least a front level kit)(new shocks)
3. Larger tires and wheels to fit the lift (no larger than 35" needed)
4. Y-pipe mod (eBay setup is fine. They use the same aluminum as Flowmaster does on there exhaust)
5. Diablo tuner
6. aFe OE Replacement Filter with Pro-Dry S (Oil-free 2-layer synthetic media)
7. A major tune up (change all fluids...and do the spark plugs)
Long list...but what a SD V10 after!
biz
Ran two different tuners... Hypertech actually made a noticeable difference but couldnt use it with the Banks system so I went to an SCT Livewire. Could never really tell it did anything other than cause my mileage to go down.
Ended up swapping my 3.73's for a set of 4.56's and was amazed. Gave me exactly what I was looking for in terms of performance increase. If only I had done it before I dropped $$$ on the Banks system, I coulda had saved big money!
You're biggest gains will come from (1) a supercharger or (2) a gear swap. Everything else is a gamble as to what you might gain.
