Help please!!
Old Jan 26, 2008 | 09:24 AM
JReinert's Avatar
JReinert
Help please!!
How does a person remove the heater box in the engine compartment? Doing headstuds and can't get it out. thanks in advance.
Old Jan 26, 2008 | 12:54 PM
toolman05kr's Avatar
toolman05kr
you don't have to take the box out. slide the studs in the holes that the box hill interfere with, holding them up with some heavy diameter o rings to keep the studs up , then carefully place the head on the block. thread in a few studs in the front for saftey then remove the o rings that you installed earlier , thread the studs in , install the washers and nuts after coating the upper threads hith molly grease included with the studs and torque to 125 ft. lbs. good luck, it's a tight fit but hith patience it will go well.
Old Jan 26, 2008 | 01:01 PM
KitsKid's Avatar
KitsKid
toolman
thanks for sharing that bit of wisdom. I just filed it away for the "someday" I might need it. I just love it when someone shares a bit of experience.
Frank
Old Jan 26, 2008 | 01:05 PM
toolman05kr
My pleasure frank, thats what we're here for.
