stroked 460
Old Dec 22, 2001 | 07:51 PM
SKID's Avatar
SKID
stroked 460
can anyone tell me what stroker combos there are for a 460?
and what has to be done to make them?
Old Dec 22, 2001 | 09:42 PM
TonyG's Avatar
TonyG
stroked 460
One combination is with a 501 c.i. with a 4.140 stroker crank and either a 6.7 or 6.8 rod.
see http://www.kb-silvolite.com/page48.htm
Old Dec 22, 2001 | 10:06 PM
Ford79's Avatar
Ford79
stroked 460
As Tony said, there's the 501 (Which i am in the process of building) with a 4.14 stroke crank, 6.700" rods, .030 overbore and custom pistons. I've seen a 512, 520, 554, 600 and more. All involve a stroker crank and some involve an aftermarket block with a bore much larger than can be had using a factory block.
Old Dec 23, 2001 | 12:21 PM
georgedavila's Avatar
georgedavila
stroked 460
Ford Racing's catalog has blocks and cranks to make almost any combo you can imagine.
Old Dec 25, 2001 | 11:49 AM
ron468's Avatar
ron468
Post stroked 460
Give " flatlanderracing.com" a try for stroker combos.
Old Dec 25, 2001 | 09:20 PM
gregaust's Avatar
gregaust
stroked 460
[updated:LAST EDITED ON 25-Dec-01 AT 10:22 PM (EST)]FORD79 ,just wondering why you chose the 501 combo. I like this combo as you only have to run a .030" bore and it enables you to use a longer rod.Are you using an aftermarket crank?TIA
Old Dec 26, 2001 | 09:28 AM
Ford79's Avatar
Ford79
stroked 460
I got a good deal on the crank and rods. The crank is brand new 4.14 stroke cast steel unit. The rods are 6.7" 4340 steel h beams. The pistons are easy to find also.
Old Dec 26, 2001 | 11:06 AM
460Gene's Avatar
460Gene
stroked 460
