Sponsored by: Real Truck
What is this?
Old Jan 25, 2008 | 10:32 PM
_Rick_'s Avatar
_Rick_
What is this?
Hi Folks,
This has been bugging me for awhile now. I've searched the web using the info printed on this thing, but I have found nothing. I'm not even sure if it's a Ford item or something from the XM or FM booster I have in my Truck. It's located behind the glove box and originally was kind of hidden with cloth black tape that it was held in place with against the passenger side panel right were you see it in the photos.
The info printed on it:
"antennas america inc pcb 00002 ta2" (with a couple of patent numbers)
Rick...
Old Jan 25, 2008 | 10:38 PM
redford's Avatar
redford
FTE Leadership Emeritus
Maybe the antenna for your keyless entry?
Old Jan 25, 2008 | 11:49 PM
armymark's Avatar
armymark
Thats the Z-coupler that uses the acetone and kerosene that people put in their fuel. It creates a ion vaper when you activate your keyless entry remote that opens the locking mechanism like redford said. Be careful with it.
Old Jan 25, 2008 | 11:53 PM
RedDragon777's Avatar
RedDragon777
all i can say if it sounds important and it is not doing any harm, leave it be
Old Jan 26, 2008 | 12:09 AM
guthrie&co's Avatar
guthrie&co
Crap you weren't supposed to find that! ......I know everything about you now thanks to my little device
Old Jan 26, 2008 | 12:31 AM
BillyBob69's Avatar
BillyBob69
HAHA Now see...if you had used my equipment, you wouldn't of had to plant that cheap, old technology bugging device...hehe
Old Jan 26, 2008 | 12:42 AM
_Rick_'s Avatar
_Rick_
I suppose I could have been more specific as to why I asked what it was besides simple curiousity.
The item is just dangling from the line/wire you see above it. It looks like it's been cut at the bottom with aprox 6" of wire left at the cut end. You can see it's not attached to anything at the bottom in the photo below as I'm holding it away from the glove box. I cannot find where the bottom end is supposed to attach to. If there is an attachment point some where behind the glove box I'm pretty sure it will take some work finding it maybe having to dis-mantle a good part of dash to get at it. UGH...
It does seem like some kind of antenna (Considering it's printed on it - "antennas america inc"). The key less entry makes sense, but it would be nice to be able to confirm this and maybe fix it if it's a necessary or functional item.
The Truck does have a KARR 4040a alarm system incorporated into the OEM keyless entry which does work with no problems. It also has a Lo-Jack unit installed. Now that I'm thinking about it,,, I have noticed that the remote range is kind of weak.
Old Jan 26, 2008 | 06:37 AM
high ho silver's Avatar
high ho silver
I thought the keyless antenna was built into the radio antenna mast on the fender.
Old Jan 26, 2008 | 10:44 AM
redford's Avatar
redford
Flux capacitor?
Old Jan 26, 2008 | 11:05 AM
RedDragon777
try fixing it, could not hurt
Old Jan 26, 2008 | 11:29 AM
Biggziff's Avatar
Biggziff
Antennas America used to supply Lojack with antennas. They also supply antennas to GPS and satellite companies.
Old Jan 26, 2008 | 11:36 AM
SpringerPop's Avatar
SpringerPop
I'd guess that it's your Lo-Jack antenna.
Pop
Old Jan 26, 2008 | 02:01 PM
BillyBob69's Avatar
BillyBob69
Contact lo-jack and ask then if they show a good signal on it. Otherwise...if all is working ok...I would just tape it back and let it be.
_Rick_'s Avatar
_Rick_
RE: armymark
armymark,
I gave up trying to find the other end of the cut wire after 2-3 hrs of searching, so it looks like maybe you're the only one that knows what this thing is. I attached the cut end of the wire to a fused wire that runs directly from the fuse panel. I haven't tested it fully yet, but when I turn the key on the unit gets very hot. I will guess that it warms up the acetone and kerosene? Is the acetone and kerosene container inside the fender where the unit is attached to? I have tapped the unit back to were I originally found it. I will be heading out this afternoon for a few hours so I will be see how it holds up.
I know it's probably a stupid question, but what does my Truck use acetone and kerosene for? and is this thing only supposed to activate when I use the keyless entry? if so then I will guess it should be running into a fuse that's on even if the key is off? I will be leaving in about 2 hrs so hopefully I will hear back from you before I leave.
Rick
Old Jan 26, 2008 | 02:02 PM
BillyBob69's Avatar
BillyBob69
Maybe a quick stop to the dealer to ask...or did you already do that and I just don't remember reading it.
