Bad shake when locked
Old Jan 25, 2008 | 05:36 PM
48' fordster's Avatar
48' fordster
Hey all... I have a 1994 F-150 and when i have the manual front lockers engaged the wheel and shifter and the shake is even worse. Its so bad in 4X4 i can't go over 65 without it feeling unsafe. Is this normal? if not how can i fix it?
Thanks in advance
Old Jan 25, 2008 | 05:40 PM
95F350XL's Avatar
95F350XL
Wow 65mph. Ive never gone that fast in 4wd. Have you cked your u-joints?
Old Jan 25, 2008 | 05:48 PM
48' fordster
Ya i forgot i was in 4 wheel when i got on the highway. but even when not in 4 wheel and just when the hubs are locked it still shakes.
haven't looked at u-joints yet...what should i look for? Just wear? the truck only has 37k miles on it.
Old Jan 25, 2008 | 05:51 PM
Skandocious's Avatar
Skandocious
I would look for components being out of balance before looking at the ujoints. Perhaps you threw a weight from your front driveshaft.
Old Jan 25, 2008 | 06:39 PM
wizzard351's Avatar
wizzard351
a d-shaft weight wont couse a big shake just a mild vibration and mabe not even that,mabe a bent d-shaft or sloppy joints
Old Jan 25, 2008 | 06:42 PM
95F350XL's Avatar
95F350XL
I had a 88 Wranger with 60K and the axle shaft u-joints were wasted from sitting. They got all rusted and when I used them they got alot of play then.
Old Jan 25, 2008 | 07:14 PM
ssidney's Avatar
ssidney
u-joint off center can cause this, remove d-shaft for a test spin, leave your hubs locked...should isolate your prob. a bit more
