Offroad & 4x4
D44 "Heavy Duty"
Old Jan 25, 2008 | 01:18 PM
masterguns2003's Avatar
masterguns2003
D44 "Heavy Duty"
So what is the deal with the "heavy duty" version? I robbed one from a 250 to put into my 150, because I needed a 4.10 rato for the front, and it was much easier to find that ratio in a f250. I know it's not, but do people actually consider it a heavy duty rear, or are they just comparing it to the regular D44?
Old Jan 25, 2008 | 01:50 PM
captain p4's Avatar
captain p4
I think the only difference is the 8 lug for the wheels.
Old Jan 25, 2008 | 04:47 PM
teds74ford's Avatar
teds74ford
That, and the "heavy duty" term people like to attach to anything they want to sell for more $$
It might have the dual piston brakes, which are better, but only if you are going to use 8 lug
Old Jan 25, 2008 | 05:23 PM
75F350's Avatar
75F350
There is a front version of the D44, and it is recognized as a Heavy Duty unit. Big hubs, big brakes, yada, yada.
There is also a HD rear axle that is used in later model Jeeps, the Viper, and a few other rides. Pretty worthless really.
Here is alink that describes the D44HD, and how it differs from other units.
http://77cj.littlekeylime.com/Dana44_2.htm
If you bought an 44hd, these are typically low pinion units, and you installed it in a 150, what did you do to mount the radius arms? How is that pinion angle?
D44's did not come in the rear of an F250, so I have to assume we are discussing a front axle.
Did you upgrade the rear axle so you do not have to run 8 lugs up front and 5 in the rear?
Old Jan 25, 2008 | 06:21 PM
masterguns2003
75F350, I kept the original TTB housings/radius arms/suspension from the 1985 F150. I only used the 3rd member out of the 1986 F250, it fit perfectly into the housing. I can't remember which axles I used. I believe the F150 axles worked out.
What the heck is a low pinion unit? I chose this rear because it was in one of my parts trucks...basically,because it was free. Will my 150 have a different "pinion angle" than the 250. Is this bad???Because I'm very concerned now...
Thanks for the link!
Old Jan 25, 2008 | 06:37 PM
75F350's Avatar
75F350
No buddy, the TTB explaination says a bunch. So many versions of the D44, and they are all a little different. If you have a TTB, then the diff will have a high pinion and use gears accordingly.
In most cases the D44HD refers to the solid axle D44 with extra webbing and large hubs. This would have been an 8 lug version with larger brakes.
As far as I know, all of the D44 TTB diffs are the same. The Larger outers, and hubs found on the 250's might be considered a heavier duty version, but is believe that the R&P is about identical, and the splines were the same, so this would permit the use of the other 44. I do not think anything other than spindles and hubs were any different.
Old Jan 25, 2008 | 07:04 PM
masterguns2003
Thanks for the info and the clarification.
ddeflyer
Aug 1, 2018 08:04 AM
PAwhiteboy
Dec 17, 2011 08:33 AM
Monsta
Modular V10 (6.8l)
15
Mar 5, 2008 02:25 PM
theconman
Dec 12, 2007 05:18 PM
Ed Trethewey
Offroad & 4x4
Nov 8, 1999 04:40 PM
