FE 390 Intake Question
Old Jan 25, 2008 | 07:15 AM
jdwoods's Avatar
jdwoods
I recently tried to find an aluminum intake manifold for my 65 Thunderbird. I found that Weiand, Edelbrock and Blue Thunder made the part. Problems with Weiand and Edelbrock was the port size fit only the 67 and up FE 390 and Blue Thunder only had med to high rise manifolds. I need a dual plane, low rise, single 4bbl, intake aluminum manifold. What are pre 67 FE 390 Ford lovers doing to solve this problem?
Old Jan 25, 2008 | 08:02 AM
Redmanbob's Avatar
Redmanbob
http://store.summitracing.com/partde...5&autoview=sku
if I'm not mistaken
Old Jan 25, 2008 | 08:47 AM
jdwoods's Avatar
jdwoods
That link goes nowhere. Sorry
Old Jan 25, 2008 | 08:53 AM
Redmanbob's Avatar
Redmanbob
weird works for me.. go to summitracing.com and post EDL-7105 in the search field.
Old Jan 25, 2008 | 10:07 AM
Bear 45/70's Avatar
Bear 45/70
The later manifolds have smaller ports and will work just fine on the older heads. The step is from smaller to larger, the step just acts as a revison pulse dam. It's going from large to small that is a no-no. FYI, the smaller ports increases the air flow velocity which improves low end preformance without hurting the top end.
Old Jan 25, 2008 | 06:56 PM
jdwoods's Avatar
jdwoods
Fe 390
Thanks everyone
Old Jan 25, 2008 | 08:10 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Also if you dont buy an intake made for the bird which I know none of...all FE intakes the carb pad is slanted..except for the t-bird runs flat if I remember right...and I have seen somewhere the wedge spacer to run on them to make em flat..as there motor sets flat in the early birds...
RJ
Old Jan 27, 2008 | 07:29 AM
baddad457's Avatar
baddad457
The T-Bird 4 bbl used a wedge spacer under the carb. The 3x2 'Bird intakes were cast with the carb pads level
Old Jan 30, 2008 | 04:33 PM
lrd56's Avatar
lrd56
cast iron 390 fe intake
i bought a 4bbl cast iron 390 manifold are they any good or are they junk.
Old Jan 30, 2008 | 05:39 PM
73F100*8Mile's Avatar
73F100*8Mile
RJ
Why are they slanted anyways? I noticed that when I got my intake out from PYP. Was that for fuel bowl leveling or something?
Old Jan 30, 2008 | 05:58 PM
Bear 45/70's Avatar
Bear 45/70
Because the engine sits different in the T-bird and doesn't need the slant.
Old Jan 30, 2008 | 09:21 PM
Hypoid's Avatar
Hypoid
Why are they slanted anyways? Was that for fuel bowl leveling or something?
Yes.
It is good for street driving, hauling, off roading; anything where you need useable torque at low RPMs. Some prefer to shave 80 pounds with an aluminum intake.
If you plan on driving with the throttle wide open most of the time, there are better intakes for that.
Old Jan 31, 2008 | 10:09 AM
lrd56's Avatar
lrd56
cast iron intake info
thanks for the info
lrd56
Old Jan 31, 2008 | 11:15 AM
55 f350's Avatar
55 f350
phenolic spacer for a 70 thunderbird is what yas need . mine had the engine at the slant { 429 w/ holley } and it's spacer was the wedge shape . got a new one 5-6 years ago before i sold it at napa . other prob, i stole the 4bbl intake off a 65 bird a buddy was parting out for my fe's . the fe stuff new or used is getting pricey so i keep my eyes open and scrounge .
Old Feb 2, 2008 | 11:38 AM
lrd56's Avatar
lrd56
Smile no phenolic spacers
ive checked the parts stores for a phenolic spacer no luck they laugh at me and call me a dinosaur.summit doesent have one.ill have have one custom made out of aluminum.i live in mohave county parts for old fords dont exist.
looki in tha classified for my fe stuff.
